Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Problem in Deflection Limit ( ETABS) Help!
 hamzeaziz
Iraq
User ID: 11936
Threads: 17
Likes: 27 in 16 posts
Given Likes: 174
10-03-2010, 09:28 AM
Hi guys
I have a problem with the value of Deflection limit in ETABS for Steel design.
As you see below there is a picture of perfrences tab and its is value.
In yellow mark all the value are as i need it for deflection limit.
[Image: 16kt0fp.jpg]
But as you see below after analysis and design the limit for deflection control are same for all type of loads, even its equal L / 472 ( 25.4mm) !!
[Image: 2wgulaq.jpg]
So where the problem is ? please someone help me!
Thanks
[-] The following 1 user Likes hamzeaziz's post:1 user Likes hamzeaziz's post
  • levanduy
 visu
User ID: 19389
Threads: 11
Likes: 447 in 180 posts
Given Likes: 377
10-03-2010, 10:22 AM
Just read the values in your input table, below your yellow cloud of first fig. This govern the design
DL limit, abs = 0.0254
Super DL+LL, abs = 0.0254 .....
It is in meter. (25.4mm)
You have to modify these values.
Visu
[-] The following 2 users Like visu's post:2 users Like visu's post
  • abaskar, hamzeaziz
 hamzeaziz
Iraq
User ID: 11936
Threads: 17
Given Likes: 174
10-03-2010, 10:29 AM
thanks
Another question, there is 3 types of deflection check in view/revise overwrite which are:
Ratio , Absolute and Both ,So which is more important Ratio or Absolute deflection ?
  How to check beam & slab deflection in ETABS budis 7 24,109 11-01-2010, 10:26 AM
Last Post: RANA WASEEM
  Problem with Steel Deck in ETABS 9.5 Sephiroth 6 10,928 09-26-2010, 10:49 AM
Last Post: mecheil.edwar
