Civil Engineering Association eBooks Geotechnical Engineering Tunneling UNDERGROUND WORKS IN HARD ROCK TUNNELLING AND MINING
 tuanpecc1
Semi Senior Member
Vietnam
User ID: 16595
Threads: 63
Likes: 1,426 in 86 posts
Given Likes: 1373
09-22-2010, 04:20 PM
ABSTRACT
The rock mass around an underground opening is subjected to a unique stress path that results in low radial confinement and both tangential loading and unloading conditions near the wall. As a result, the rock mass strength near underground excavations is controlled by failure mechanisms dominating at low confinement.
Hence, when constructing underground works in hard rock, two general scenarios are encountered:
(1) structurally controlled gravity-driven failures; and (2) stress-induced failure with spalling and slabbing. The former process is predominant when both the radial and the tangential stresses are low, where as the latter is prevalent when high tangential stresses drive rock mass failure. Whereas structurally controlled failures are most frequently observed at shallow depths and slabbing failure is commonly found at great depth, mining and tunnelling experience shows that these failure processes may be encountered at essentially
any depth. In this keynote the authors provide an overall framework for assessing the stability of underground openings in hard rocks, regardless whether the excavations are required for mining, nuclear waste or civil engineering application.
[Image: 18272239124347150667.png]
[-] The following 14 users Like tuanpecc1's post:14 users Like tuanpecc1's post
  • Nilupa, ELAHI1979, daywalker, kowheng, nhim4mat2006, 2824, oanm2000, Notter, zrilek, Evandrojr, Jackass, peymanlord, fer962933, shadabg
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5545
10-31-2011, 08:46 AM
[Image: password.png].
[-] The following 2 users Like 3fan's post:2 users Like 3fan's post
  • peymanlord, fer962933
  TBM Tunnelling in Jointed and Faulted Rock by Nick Barton pppppp 10 9,184 07-27-2018, 12:07 AM
  Rockbursts: Case Studies from North American Hard-Rock Mines OSHO 0 2,352 11-13-2017, 03:31 AM
Last Post: OSHO
  Mining Methods in Underground Mining by Atlas Copco pppppp 4 3,727 11-24-2015, 12:11 PM
Last Post: brandizzo
  Concrete in underground Works gianniorlati 1 1,589 03-08-2015, 05:18 PM
Last Post: Veggeta
  Class notes on Underground Excavations in Rock (2006) clerigo 3 3,223 10-26-2012, 09:04 AM
Last Post: shadabg
  Minning and Rock Construction Technology Desk Reference,Rock Mechanics, Drilling & Bl mybest 2 2,721 08-11-2012, 10:19 AM
Last Post: shadabg
  Deep Mining Challenges: International Mining Forum 2009 mybest 1 1,934 05-30-2012, 10:14 AM
Last Post: wobmot
