Bridge Construction Set v1.30
[Image: 55291236845232994302.jpg]
Bridge Construction Set is about building a bridge that doesn't break, although watching your bridge creation break and plunge a train into the watery depths below can be half the fun. In Bridge Construction Set you design and build bridges and then stress test them to see how your creations hold up under pressure. When test vehicles pass over your bridge and make it safely across you know you've succeeded. If they plummet into the river you know you need to go back to the drawing board.
The robust physics deployed in Bridge Construction Set let you build a unlimited variety of bridges. Try your hand at giant suspension bridges, complex drawbridges, multi-level train and automobile bridges and everything in between. The 3D graphics allow you to view your bridge from any angle including a first person view - it's like being strapped to the front of the train when your bridge is first tested...
Bridge Construction Set includes many types of bridge building levels in varying degrees of difficulty from simple to complex with a tutorial to get you started building bridges. A Level Editor is also included so you can create your own levels and trade them with others.
Bridge Construction Set features:
* Forty unique levels.
* Build Suspension Bridges, Draw Bridges and others.
* Building materials include cables, hydraulics and more.
* Fifteen types of vehicles that will test your bridges.
* Over forty types of 3d objects decorate the levels.
* Includes a Level editor to create your own levels.
* Includes a Map packer to create custom map packs.
* Chronic Logic sponsored bridge building Contests
Just for relax time :)
[-] The following 14 users say Thank You to abudabeeja for this post:
  • oanm2000, oanm2000, aidil01, aidil01, emmi, emmi, piyush2678, piyush2678, ia_ranco, simanta, julioreptil, masafi_15, sudershan, pinh881
