Registry Booster
[Image: 95300225578604624171.jpg]
The Problem
Have you noticed that the longer you have your computer, the slower it runs and the more it crashes? Often this is because whenever you install or uninstall software, add or remove hardware, or change your computer’s settings, the Windows registry is updated. These changes can leave the registry fragmented, with obsolete, corrupted and, in some cases, harmful files. Over time the registry starts to get bogged down and conflicts emerge. Left unchecked, your system will become increasingly unstable, run more slowly and crash more frequently.
The Solution
RegistryBooster is the easy answer to all your Windows registry problems. This award winning software starts by conducting a deep scan of your registry, checking for file extension errors and other registry conflicts. RegistryBooster will then repair or remove unused, corrupted and harmful files so optimizing your PC’s performance. You can then use regular scans to keep your registry structured and your PC speeding along at peak efficiency. With RegistryBooster you’ll see immediate increases in performance and decreases in system conflicts.
[-] The following 2 users say Thank You to verongskey for this post:
  • lednar_ved, tolesa54
Registry Winner v6.0.9.26 Multilingual paladin 2 2,349 01-04-2011, 05:14 AM
Last Post: haze
