Ram Connection 5.00.01.43
This program provides unequaled flexibility for the design of different types of shear, moment, bracing and splice connections. It is based upon the provisions of the ANSI/AISC 360-05 for Steel Design Specifications and considers mainly W and HSS shapes.
You can call the program after RAM Structural System or RAM Advanse and use automatically the results of the analysis and design of members.
The connection design can also be customized to adhere to your typical office standards.
Design in RAM Connection
Connections can be designed by one of these three methods in RAM Connection (RC) and RAM Connection Standalone (RCSA) programs. The first method could be called a "trial and error" procedure. In this method the engineer defines a database of different connections (note that many connections are already supplied with the program itself), assigning one to the joint and the program will indicate if it is suitable for the joint. The engineer can then manually either assign another connection, or adjust the first connection he/she assigned. The second method would be to have the program search through a list of the database connections to find the first one in the list that works for the joint (geometry and forces). The third method is similar to the second but rather than search through a predefined list the program will assign a single smart connection to the joint. These three methods provide the engineer with complete control over the design of their individual connections.
screenshots:
[Image: ramcon1.jpg]
[Image: ramcon2.jpg]
Original link
Links changed and alive.
