07-29-2010, 02:09 PM
Bentley LEAP PC-HELP 02.01.02 (Trial)
PC-Help is a Windows-based software program for the design and analysis of connections used primarily in the precast/prestressed industry. The program follows the PCI Design Handbook and addresses the following areas:
Welded Headed Studs
Weld Groups
Bearing Pads
Connection Angles
Shear Friction
Bearing on Plain Concrete
Reinforced Concrete Bearing
Column Base Plates
Concrete Brackets or Corbels
Dapped End Connections
Beam Ledges
Hanger Connections (Cazaly and Loov)
Steel Converter
Trial
![[Image: screen.png]](http://forum.civilea.com/postgen/screen.png)
![[Image: 50180170941562615341.gif]](https://pic.civilea.com/images/50180170941562615341.gif)
***************************************![[Image: password.png]](http://forum.civilea.com/postgen/password.png)
***************************************IMPORTANT NOTICE: You may use this software for evaluation purposes only.
