Civil Engineering Association Software Software Product Bentley Products STAAD Offshore 2.0.6.1
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,981 in 4,091 posts
Given Likes: 612
Points:282,462 EP
07-25-2010, 03:54 PM
STAAD.Offshore for use with STAAD.Pro. The program consists of a suite of pre and post analysis processing modules for structures modelled in the structural analysis and design program STAAD.Pro. The program is operated from a single interface from which the required modules can be set up and operated.
There are three primary modules to the STAAD.Offshore:
The Wave Load Module calculates wave loads on structures using either STREAM function, STOKES 5th Order Theory, AIRY theory, or a user defined grid wave. The program generates a STAAD.Pro loading data for the stiffness analysis.
The Transport Load Module calculates the inertia forces on a structure and generates the STAAD.Pro loading data for the stiffness analysis.
The Fatigue Module is a deterministic fatigue program to calculate the fatigue lives of tubular joints.
Select Bentley SELECT XM License.... when installing.
I received 1000 Days and i suppose is because one old dll from other medicine was present in my computer (IEGLicLib.dll) before (installing Autopipe with this dll - see Autopipe 09.02.03.02 or other Bentley using it and posted before).
[Image: 17124080669126661679.gif]
[Image: 34481693499491686779.gif]
[-] The following 16 users Like BennyP's post:16 users Like BennyP's post
  • Dell_Brett, maad59, haze, hadeest, triance, d3d3n, rjvp_1712, prash_mce, ravisbassi, zbizafar, engiman27, zrilek, spat, udhay, ting tsai huang, malc
  STAAD.Offshore (Version: 03.00.01.02) Installation only sandeepb 2 7,790 01-19-2013, 03:09 PM
Last Post: joker™
