Bridge Modeler/LARS 04.00.10.00 (Trial only)
BridgeModeler is the common thread of the BridgeKey suite of programs for bridge engineering. BridgeModeler is a series of programs with a standard Windows Graphical User Interface (GUI), which can read, display, edit and write data files for all programs that operate under the BridgeKey program group. It provides the user with the ability to interactively create, view and modify three-dimensional numerical models of bridge members for the construction of a complete three-dimensional bridge model. BridgeModeler can also interactively define, view and modify bridge-loading conditions that may be applied to bridge structures. BridgeModeler performs the following functions:
Create new bridge models
Modify and update existing bridge models
Visually display and verify a bridge model
Visually display and verify applied loads
Generate input for various analysis programs
Analyze models using the LARS load rating engine.
Display graphically and textually analysis program results
BridgeModeler also provides an interface to all BridgeKey applications by use of its Import/Export functions.
BridgeAnalysis is part of the BridgeKey suite of programs for bridge engineering. At the current time, it allows for the standalone analysis of bridge data stored in AASHTOWare BARS or C.W. Beilfuss and Associates LARS formats. Lateral Load Analysis data can also be processed. Future analysis engines may be incorporated in the future so that more types of data will be able to be analyzed through this one standard GUI. The BridgeAnalysis application gives the ability to create and modify data, run analysis on the data, and then view, save, and print the output.
TRIAL ONLY
[Image: 80198535796767879884.gif]
[-] The following 13 users say Thank You to BennyP for this post:
  • haze, Dell_Brett, Gabemzaman, abudabeeja, oanm2000, teastf, ALSKERT, ChisTeam, Williams, spat, ting tsai huang, dquan373, Rapaig
Bentley LEAP Bridge Suite v8i (SELECT series 1) 09.00.03.02 (Trial) BennyP 0 3,954 07-28-2010, 04:01 PM
Bentley Structural Modeler V8i (SELECTseries 1) 08.11.07.61 (trial only) BennyP 0 2,232 04-04-2010, 02:32 PM
