Worked examples according to EN1993-1-3
Author: ECCS TC7 TWG 7.5 | Size: 26.2 MB | Format: PDF | Quality: Scanner | Publisher: ECCS | Year: 2008 | pages: 235 | ISBN: 92-9147-000-86
![[Image: 65160987765886297461.jpg]](https://pic.civilea.com/images/65160987765886297461.jpg)
ECCS has published document No. 114 Preliminary worked examples according to Eurocode 3 Part 1.3 (2000) prepared by ECCS TC 7 using the pre-standard ENV 1993-1-3. The original aim was to check the applicability and accuracy of the pre-standard and assist the practical use of the provisions.
This new publication replaces ECCS document No. 114. The examples have been updated following the provisions given in EN 1993-1-3. Some new examples have been also included. These examples show applicability of design provisions in EN 1993-1-3 in practice. They also help in interpretation of the guidance given in the code.
Chapter 2 contains examples related to one industrial building. Different aspects related to the design of structural components have been included.
-Example A: Roof sheeting
-Example B: Liner trays
-Example C: Purlins
-Example D: Portal frames
-Example E: End wall and wind bracing
Chapter 3 contains additional examples for specific structural elements or features of EN 1993-1-3, which are included to assist in practical use of the provision.
-Example F: C-section in compression and bending about axis of symmetry
-Example G. U-section in bending and compression
-Example H: C-section in compression
-Example I: Hat section upper chord of lattice girder
-Example J: Sheeting with stiffeners in flange and web
-Example K: Inelastic reserve of sheeting
-Example L: Double C-section as end column
The calculations are based on the provisions of EN 1993-1-3. Also parts EN 1993-1-5 and EN 1993-1-1 are required in the calculations. In some cases engineering judgement has been followed. If other methods in addition to Eurocode 3 have been used it has been clearly noted in the examples.
Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation:
👉 CLICK HERE 👈
