Civil Engineering Association eBooks Structural Books Concrete Binders for Durable and Sustainable Concrete by P-C AitCin
 rendel_©
Philippine
User ID: 1138
Threads: 122
Likes: 2,115 in 214 posts
Given Likes: 2687
10-21-2009, 07:41 PM (This post was last modified: 12-14-2011, 11:17 PM by usman.)
Binders for Durable and Sustainable Concrete (Modern Concrete Technology Series) by P-C AitCin
[Image: kggsd42xjtyukaxw6nzg.jpeg]
Publisher: Routledge | August 20, 2007 | ISBN: 0415385881 | Pages: 528 | PDF | 12.7 MB
Modern hydraulic binders can be used effectively with Portland cement and supplementary cementitious materials to produce durable concrete. They also provide a means of recycling by-products from other industries and of decreasing the emission of greenhouse gases.
The first binders were discovered in ancient times when it was observed that new pozzolans mixed with lime could harden under water; and in the middle of the nineteen century the first artificial hydraulic binder, Portland cement, was discovered. By modifying the four basic oxides in the limestone and clay mix used in the production of Portland cement it is possible to modify significantly the practical properties of the clinker, and consequently the performance of the fresh and hardened concrete in which it is used.
Chemical admixtures can be used to disperse cement particles without the use of extra water, and so make concrete which is highly resistant to penetration by aggressive agents and of high durability and strength. Supplementary cementitious materials or fillers can be mixed with Portland cement to produce modern hydraulic binders and improve the ecological performance of concrete. The hydration process of a modern hydraulic binder is becoming quite complex because it involves the chemical reactivity of Portland cement clinker, of supplementary cementitious materials and of different types of admixtures. This has already resulted in great technological achievements such as high-performance concrete, self leveling concrete, confined concrete, high-performance roller compacted concrete, fiber reinforced concrete, and reactive powder concrete.
Download Links:
Password:
[-] The following 25 users Like rendel_©'s post:25 users Like rendel_©'s post
  • niki102, niki102, aslam, aslam, concreteok, concreteok, baikur, baikur, kowheng, kowheng, ruaumoko, ruaumoko, zrilek, Administrator , sangen, boycv, HerrMeier, Nilupa, Tulanh, rkce, oanm2000, mgdario, Dell_Brett, shadabg, lisine
11-16-2011, 09:34 PM
PDF, 12.67 MB
If you like this publication, CivilEA's Team strongly suggest you to buy it! Support the authors!
[-] The following 6 users Like Grunf's post:6 users Like Grunf's post
  • Dell_Brett, ting tsai huang, gulilero, rkce, Jackass, oanm2000
Likes: 12,075 in 1,233 posts
04-17-2012, 07:01 AM
[-] The following 3 users Like pezhmankhan's post:3 users Like pezhmankhan's post
  • Jackass, Dell_Brett, shadabg
12-27-2012, 10:00 AM
PDF / RAR : 12.7 / 12.2 mb
  Sulfur Concrete for the Construction Industry: A Sustainable Development Approach TAFATNEB 2 2,285 08-08-2021, 12:18 PM
  Concrete Durability: A Practical Guide to the Design of Durable Concrete Structures carolinandra 1 2,180 05-01-2019, 03:06 AM
  Sustainable Concrete Solutions 1st Edition febo927 1 1,928 07-03-2018, 07:34 PM
  The Sustainable Use of Concrete ir_71 1 1,879 01-19-2016, 03:43 PM
Last Post: ibg0203
  Concrete: The Sustainable Infrastructure Material for the 21st Century mahyarov 0 1,394 10-27-2012, 08:56 AM
Last Post: mahyarov
  CEB: Durable Concrete Structures, 2nd ed bridgedut 4 4,101 10-21-2012, 02:12 PM
Last Post: shadabg
  Fundamentals of Durable Reinforced Concrete Grunf 1 2,290 09-29-2012, 04:53 AM
Last Post: oscargon
