09-10-2012, 06:42 AM
The initial title was too long. User can't edit the first post in the thread. I corrected the title. Try now.
09-16-2012, 01:58 PM
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
10-16-2012, 07:09 AM
Same happened to me as Post #443 of 3fan
I think the reason was firefox update That is why now I am using Internet explorer (iexplore) While ago when firefox upgraded to 15.1 similar things happened, I reinstalled the older version of firefox, and problem was solved
10-17-2012, 06:09 PM
Grunf just made a huge point donation to david. But who's david
10-17-2012, 06:43 PM
Few months ago the same bug appeared. And at that time seems that it had been solved.
Admin , how can I do to use again features in reply text editor because they are not working.
10-17-2012, 06:53 PM
This is an old bug - see post #174 here
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 The main problem is my friend grunf make the same the second time (the others were frequo and mybest but they have a better memory and stoped donating points to this david). And the bug never was solved (not only david received imaginary points in statistics but other user too). As a matter of fact no one gave and no one received points - only in statistics records you can see this donation.
10-19-2012, 08:12 AM
^ we disabled this plug-in temporary to find bugs.
10-20-2012, 12:56 PM
One more:
![]() I'm using Firefox v.16.0.1. As I'm writing this post, I noted that it is not possible to use the post buttons to generate codes for images [img] nor for links Content of this section is hidden, You must be registered and upgrade your account to see this content. . If you press the button for lets say coding the link this appears: [undefined=undefined] and in upper right corner violet sign appears saying [close tags]. When you press this violet sign, nothing happens, thus every code needs to be written manually. |
