07-28-2012, 06:14 AM
The FPS earthquake resisting system: experimental report
Zayas, Victor A.; Low, Stanley S.; Mahin, Stephen A.
UCB/EERC-87/01, Earthquake Engineering Research Center, University of California, Berkeley, 1987-06, 98 pages (530/Z32/1987)
The advantages of the friction pendulum system (FPS) connections are discussed. The high-strength steel connection consists of an articulated friction slider which moves on a spherical concave surface, resulting in small-amplitude pendulum motions of the supported structure. The connections provide seismic isolation and ductility for the building, with the friction slider effectively absorbing the earthquake's energy. Building models using the FPS system were subjected to severe and moderate earthquake motions on the shaking table at the Earthquake Engineering Research Center, Univ. of California at Berkeley. The responses of these building models were compared with responses predicted using computer simulations. This report summarizes the test procedures and results and presents comparisons between the measured and predicted responses.
![[Image: Download.png]](http://forum.civilea.com/postgen/icon/Download.png)
PDF 4.24 MB | RAR 3.48 MB
![[Image: 93873419594313549409.jpg]](https://pic.civilea.com/images/93873419594313549409.jpg)
