Civil Engineering Association eBooks Journals, Papers and Presentations Journal: Earthquake Engineering & Structural Dynamics
 faros3000
Senior Member
User ID: 61
Threads: 24
Likes: 1,265 in 175 posts
Given Likes: 1793
06-28-2012, 03:11 PM
Journal: Earthquake Engineering & Structural Dynamics - Vol 37, Issue 1
Size: 4 MB | Format: PDF | Publisher: WILEY
[Image: 63572746972104571941.jpg]
Earthquake Engineering and Structural Dynamics
Published under auspices of
Edited by:
Anil K. Chopra, Peter Fajfar, Masayoshi Nakashima
Print ISSN: 0098-8847
Online ISSN: 1096-9845
Frequency: Fifteen times a year
CONTENT OF THIS ISSUE
Experimental multi-level seismic performance assessment of 3D RC frame designed for damage avoidance (pages 1–20)
Brendon A. Bradley, Rajesh P. Dhakal, John B. Mander and Louman Li
Compensation of actuator delay and dynamics for real-time hybrid structural simulation (pages 21–42)
M. Ahmadizadeh, G. Mosqueda and A. M. Reinhorn
Cyclic behavior of laterally loaded concrete piles embedded into cohesive soil (pages 43–59)
Rabin Tuladhar, Takeshi Maki and Hiroshi Mutsuyoshi
Effects of two alternative representations of ground-motion uncertainty on probabilistic seismic demand assessment of structures (pages 61–79)
F. Jalayer and J. L. Beck
Computational and rapid expected annual loss estimation methodologies for structures (pages 81–101)
Kevin M. Solberg, Rajesh P. Dhakal, John B. Mander and Brendon A. Bradley
Apparent damping induced by spurious pitching in shaking-table testing (pages 103–119)
F. J. Molina, G. Magonette, B. Viaccoz and M. Géradin
Decentralized robust control of building structures under seismic excitations (pages 121–140)
Tian-Wei Ma, Ning-Shou Xu and Yu Tang
Seismic strengthening of an under-designed RC structure with FRP (pages 141–162)
M. Di Ludovico, A. Prota, G. Manfredi and E. Cosenza
Information is not knowledge.
Albert Einstein
[-] The following 19 users Like faros3000's post:19 users Like faros3000's post
  • ruaumoko, jjingo, zrilek, Grunf, sodapas, Quantumm, gelbert, 3fan, malc, kowheng, oanm2000, Dell_Brett, warbeast, mary, andersen3, ssobhan, Gkatzogias, slowet, TAFATNEB
 faros3000
Senior Member
User ID: 61
Threads: 24
Given Likes: 1793
06-30-2012, 10:27 PM
Journal: Earthquake Engineering & Structural Dynamics - Vol 37, Issue 2
Size: 3 MB | Format: PDF | Publisher: WILEY
Edited by:
Spherical sliding isolation bearings with adaptive behavior: Theory (pages 163–183)
Daniel M. Fenz and Michael C. Constantinou
Spherical sliding isolation bearings with adaptive behavior: Experimental verification (pages 185–205)
Spectral analysis and design approach for high force-to-volume extrusion damper-based structural energy dissipation (pages 207–223)
Geoffrey W. Rodgers, John B. Mander, J. Geoffrey Chase, Rajesh P. Dhakal, Nicholas C. Leach and Caleb S. Denmead
Experimental investigation on a base isolation system incorporating steel–Teflon sliders and pressurized fluid viscous spring dampers (pages 225–242)
Stefano Sorace, Gloria Terenzi, Georges Magonette and Francisco J. Molina
Experimental characterization, modeling and identification of the NEES-UCSD shake table mechanical system (pages 243–264)
O. Ozcelik, J. E. Luco, J. P. Conte, T. L. Trombetti and J. I. Restrepo
Numerical characteristics of peer-to-peer (P2P) internet online hybrid test system and its application to seismic simulation of SRC structure (pages 265–282)
Tao Wang, Nobuya Yoshitake, Peng Pan, Tae-Hyung Lee and Masayoshi Nakashima
Seismic isolation by rubber–soil mixtures for developing countries (pages 283–303)
Hing-Ho Tsang
Seismic analysis of two-way asymmetric building systems under bi-directional seismic ground motions (pages 305–328)
Jui-Liang Lin and Keh-Chyuan Tsai
Albert Einstein
[-] The following 18 users Like faros3000's post:18 users Like faros3000's post
  • 3fan, Grunf, malc, kowheng, Dell_Brett, warbeast, zrilek, subin91, blaze, mary, andersen3, ssobhan, Gkatzogias, miquan, slowet, oanm2000, sodapas, ruaumoko
 faros3000
Senior Member
User ID: 61
Threads: 24
Given Likes: 1793
07-05-2012, 08:04 PM
Journal: Earthquake Engineering & Structural Dynamics - Vol 37, Issue 3
Size: 5 MB | Format: PDF | Publisher: WILEY
Edited by:
Probabilistic seismic hazard analysis: Early history (pages 329–338)
Robin K. McGuire
Novel coupling Rosenbrock-based algorithms for real-time dynamic substructure testing (pages 339–360)
O. S. Bursi, A. Gonzalez-Buelga, L. Vulcan, S. A. Neild and D. J. Wagg
System identification applied to long-span cable-supported bridges using seismic records (pages 361–386)
Dionysius M. Siringoringo and Yozo Fujino
Generation of fragility curves for Turkish masonry buildings considering in-plane failure modes (pages 387–405)
M. Altuğ Erberik
Experimental and theoretical study on two types of shape memory alloy devices (pages 407–426)
Hui Li, Chen-Xi Mao and Jin-Ping Ou
Optimization of structural control via a smart NEURO-FBG control system (pages 427–445)
Tzu-Kang Lin, Jen-Chang Chiu and Kuo-Chun Chang
A review of adverse effects of damping in seismic isolation (pages 447–465)
Ioannis Politopoulos
Non-linear seismic analysis and vulnerability evaluation of a masonry building by means of the SAP2000 V.10 code (pages 467–485)
Laurent Pasticier, Claudio Amadio and Massimo Fragiacomo
Assessment of the frequency domain decomposition technique by forced-vibration tests of a full-scale structure (pages 487–494)
C. P. Lamarche, P. Paultre, J. Proulx and S. Mousseau
Albert Einstein
  • 3fan, paitaconst, kowheng, malc, zrilek, andersen3, Dell_Brett, pingfan2, ssobhan, mary, warbeast, Grunf, Gkatzogias, miquan, slowet, oanm2000, sodapas, ruaumoko
 faros3000
Senior Member
User ID: 61
Threads: 24
Given Likes: 1793
07-07-2012, 09:21 PM
Journal: Earthquake Engineering & Structural Dynamics - Vol 37, Issue 4
The Journal of the International Association for Earthquake Engineering
Edited by:
Transform methods for frequency-dependent complex stiffness to time domain using real or imaginary data only (pages 495–515)
Naohiro Nakamura
Output-only structural identification in time domain: Numerical and experimental studies (pages 517–533)
M. J. Perry and C. G. Koh
A design-variable-based inelastic hysteretic model for beam–column connections (pages 535–555)
Gun Jin Yun, Jamshid Ghaboussi and Amr S. Elnashai
Restoring capability of bilinear hysteretic seismic isolation systems (pages 557–575)
Christos P. Katsaras, Telemachos B. Panagiotakos and Basil Kolias
Seismic behaviour of shallow foundations: Shaking table experiments vs numerical modelling (pages 577–595)
Roberto Paolucci, Masahiro Shirato and M. Tolga Yilmaz
Stability analysis of SDOF real-time hybrid testing systems with explicit integration algorithms and actuator delay (pages 597–613)
Cheng Chen and James M. Ricles
A note on classical damping matrices (pages 615–626)
J. Enrique Luco
Seismic self-centering steel beam-to-column moment connections using bolted friction devices (pages 627–645)
Keh-Chyuan Tsai, Chung-Che Chou, Chi-Lon Lin, Pei-Ching Chen and Sheng-Jhih Jhang
Slide roof system for dynamic response reduction (pages 647–658)
Zhichang Tian, Jiaru Qian and Liming Zhang
Intelligent computational paradigms in earthquake engineering, edited by Nikos D. Lagaros and Yiannis Tsompanakis, IGI Publishing, New York, 444 pages. ISBN: 1-59904-099-9
Anil K. Chopra
Albert Einstein
  • zrilek, Dell_Brett, malc, pingfan2, 3fan, ssobhan, kowheng, subin91, tluc, warbeast, Grunf, ircba, Gkatzogias, slowet, oanm2000, sodapas, mahyarov, ruaumoko
 faros3000
Senior Member
User ID: 61
Threads: 24
Given Likes: 1793
07-16-2012, 11:50 PM
Journal: Earthquake Engineering & Structural Dynamics - Vol 37, Issue 5
Size: 7 MB | Format: PDF | Publisher: WILEY
Edited by:
On the response of yielding seismically isolated structures (pages 659–679)
Masaru Kikuchi, Cameron J. Black and Ian D. Aiken
Probabilistic evaluation of seismic performance of 3-story 3D one- and two-way steel moment-frame structures (pages 681–696)
Hiroyuki Tagawa, Gregory MacRae and Laura Lowes
On the reliability of long-period response spectral ordinates from digital accelerograms (pages 697–710)
Roberto Paolucci, Antonio Rovelli, Ezio Faccioli, Carlo Cauzzi, Daniela Finazzi, Manuela Vanini, Carola Di Alessandro and Giovanna Calderoni
Selection of optimal intensity measures in probabilistic seismic demand models of highway bridge portfolios (pages 711–725)
Jamie E. Padgett, Bryant G. Nielson and Reginald DesRoches
Local retrofit of exterior RC beam–column joints using thin RC jackets—An experimental study (pages 727–746)
Chris G. Karayannis, Constantin E. Chalioris and George M. Sirkelis
Experimental study of a hybrid platform for high-tech equipment protection against earthquake and microvibration (pages 747–767)
Y. L. Xu, Z. F. Yu and S. Zhan
Strengthening and rehabilitation of RC beam–column joints using carbon-FRP jacketing and epoxy resin injection (pages 769–790)
Chris G. Karayannis and George M. Sirkelis
Freestanding block overturning fragilities: Numerical simulation and experimental validation (pages 791–808)
Matthew D. Purvance, Abdolrasool Anooshehpoor and James N. Brune
Experimental seismic investigation of Sefid-rud concrete buttress dam model on shaking table (pages 809–823)
A. R. Ghaemmaghami and M. Ghaemian
Albert Einstein
[-] The following 14 users Like faros3000's post:14 users Like faros3000's post
  • kowheng, joker™, malc, warbeast, slowet, tluc, zrilek, oanm2000, Dell_Brett, Gkatzogias, sodapas, mahyarov, ruaumoko, ssobhan
 Gkatzogias
Greece
User ID: 31724
Threads: 2
Likes: 88 in 19 posts
Given Likes: 384
09-21-2012, 07:59 AM
Earthquake Engineering & Structural Dynamics: Vol. 41, Issue 1, January
Author: Various | Size: 6.39 MB | Format: PDF | Quality: Original preprint | Publisher: Wiley-Blackwell | Year: 2012 | pages: 1-157
Manuscripts:
01. A simple image-based strain measurement method for measuring the strain fields in an RC-wall experiment (pages 1–17)
Yuan-Sen Yang, Chang-Wei Huang and Chiun-lin Wu
02. Minaret behavior under earthquake loading: The case of historical Istanbul (pages 19–39)
C. S. Oliveira, E. Çaktı, D. Stengel and M. Branco
03. Dynamic response and optimal design of structures with large mass ratio TMD (pages 41–60)
Maurizio De Angelis, Salvatore Perno and Anna Reggio
04. Seismic risk assessment of interdependent critical infrastructure systems: The case of European gas and electricity networks (pages 61–79)
Karmen Poljanšek, Flavio Bono and Eugenio Gutiérrez
05. Seismic vulnerability assessment to slight damage based on experimental modal parameters (pages 81–98)
C. Michel, P. Guéguen and M. Causse
06. Semiactive fuzzy control of the seismic response of building frames with MR dampers (pages 99–118)
Diptesh Das, T. K. Datta and Alok Madan
07. Seismic response of structures with coupled vertical stiffness–strength irregularities (pages 119–138)
Vinod K. Sadashiva, Gregory A. MacRae and Bruce L. Deam
08. Dynamic interaction of bridge–train system under non-uniform seismic ground motion (pages 139–157)
X. T. Du, Y. L. Xu and H. Xia
[Image: comments.png]
Open access papers: These can be downloaded directly from Wiley Online Library
[-] The following 9 users Like Gkatzogias's post:9 users Like Gkatzogias's post
  • warbeast, kowheng, Grunf, ibmarin, zrilek, sodapas, mahyarov, Dell_Brett, ssobhan
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
11-05-2012, 12:50 PM
Earthquake Engineering & Structural Dynamics Vol. 40 Issue 1 - 15
Size: 54 MB | Format: PDF | Quality: Original preprint | Publisher: Wiley Online Library | Year: 2011
Journal of Earthquake Engineering & Structural Dynamics
sorry for not default password.
I have uploaded this file far before our new rule
[-] The following 9 users Like mybest's post:9 users Like mybest's post
  • david-smith, kowheng, mahyarov, malc, Dell_Brett, Grunf, zrilek, Gkatzogias, ssobhan
  The AISC Engineering Journal Archive [1964-2001] agelos100 2 8,297 03-02-2020, 01:50 AM
  ACI Structural Journal Collection essenza 23 60,881 04-21-2016, 07:41 PM
Last Post: bridgeengineer
  AISC Engineering Journal Fourth Quarter 2014 Volume 51, No. 4 malc 1 6,864 10-15-2014, 07:26 AM
Last Post: Saze808
  Journal of Engineering Mechanics - Papers lisine 3 8,033 06-28-2013, 09:24 AM
  Journal of Materials in Civil Engineering - Papers lisine 3 8,764 06-28-2013, 09:24 AM
  Journal of Structural Engineering - Papers lisine 10 19,772 06-07-2013, 06:41 AM
  Journal Engineering Structures - Papers lisine 6 12,665 04-10-2013, 07:01 AM
