Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Experimental Verification of Viscous Damping Modeling for ITHA
[Request] Experimental Verification of Viscous Damping Modeling for ITHA
06-22-2012, 08:04 PM
Dear members,
can someone share this article:
Experimental Verification of Viscous Damping Modeling for Inelastic Time History Analyzes
by: Lorenza Petrinia*, Claudio Maggib, M. J. Nigel Priestleyc & G. Michele Calvibc
pages 125-145
Keywords: Viscous Damping Modeling, Shake Table Tests, Theory/Experiment Comparison, Time History Analysis
Abstract:
Inelastic time history analyzes (ITHA) are recognized as the most suitable tool for describing the behavior of structures under seismic actions. It is clear that the reliability of ITHA results is strongly dependent on the modeling choices. One of the aspects still debated, in spite of a large amount of research, is the modeling of viscous damping forces. In the case of a single degree of freedom (SDOF) structure, the damping not represented by hysteretic response is commonly assumed proportional to the square root of the system stiffness: typically in the research papers it is not declared whether the initial or tangent-stiffness is considered. Recent research has shown that initial or tangent-stiffness proportional damping can give very different results in terms of energy dissipation, and peak response displacement. In this work, experimental and numerical tests performed to detect the most appropriate model are described and discussed.
Available at:
Many thanks in advance.
Kind regards,
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
06-23-2012, 01:40 AM
Here
[-] The following 6 users Like mybest's post:6 users Like mybest's post
  • faros3000, david-smith, malc, Grunf, marion33, zrilek
 amir201
User ID: 19015
Likes: 13 in 3 posts
Given Likes: 27
06-29-2012, 09:36 PM (This post was last modified: 06-29-2012, 10:24 PM by 3fan.)
here u are this article at this link
[-] The following 2 users Like amir201's post:2 users Like amir201's post
  • malc, zrilek
  [REQUEST] Journal of Sound and Vibration - Equivalent viscous damping 3fan 4 2,894 05-15-2012, 02:27 PM
  [REQUEST] Comparison of Methods for Computing Equivalent Viscous Damping Ratios of Structures 3fan 1 1,903 02-16-2012, 08:55 AM
  [REQUEST] Comparison of distribution methods for viscous damping coefficients to buildings mahesu219 3 2,360 03-27-2011, 09:56 AM
Last Post: hich
