Civil Engineering Association eBooks Bad Posts (eBooks) Civil & Structural Engineering Reference
Thread Closed
 nassara
User ID: 11225
Threads: 16
Likes: 596 in 44 posts
Given Likes: 105
04-13-2012, 06:23 PM (This post was last modified: 04-14-2012, 03:21 AM by BennyP.)
Size: 1.39 GB | Format: PDF | Quality: Unspecified
[Image: 91289844400020826922.png]
3DS Max Tutorials
2003 International Plumbing
ACI Design Handbook
ACI Mix Design 2
Advanced Mathematics
AISC ASD Manual 9th Edition
AISC ASD 89
AISC Design Guides
Architecture-ebook-Design for construction SCI
Architecture-ebook-Steel designers Manual 6th ed.
Arc-welding
ASCE7-05 Seismic
ASD vs. LRFD
ASTM Stainless Steel
Basic Structural Theory
Beam Design Formulas with Shear and Moment Diagrams
Bridge Design Manual 2006
Bridge Design using STAAD
Building Design Process
Calculus
Civil Engineering Hydraulics
Code of Conduct for Professionals in Civil Engineering
Composite Beam Design
Composite Structures of Steel and concrete
Concrete Construction engineering handbook 2nd Ed.
Concrete Example SI
Concrete Pavement Manual
Concrete Pipe Design Manual
Connections Handbook 2002
Construction Handbook
Cranes Design, Practice and Maintenance
Curved bEams
Decision Making in engineering design
Design of Fully restrained moment connections AISC LRFD
Design and Construction 1
Design and construction
Design and construction of concrete formwork
Design and construction of driven pile foundation
Design of Curved beams
Design of footings
Design of Monorail Systems
Design of Pile Foundations
Design of Prestressed concrete
Design of Reinforced Concrete ACI 05
Design of Shear Wall Buildings
Design of Steel Footbridges
Design of Steel Shelter
Design of Timber Structures
Design of Portal Frame
Differential Equations
Dynamic Analysis
Earthquake engineering analysis and design
Engineered Plumbing Design II
Engineering Dynamics
Engineering Economic Analysis
Engineering Fluid Mechanics
EPRI Manual on Estimating Soil Properties for Foundation DEsign
ETABS Composite Floor FRame DEsign Manual
Evaluation of the seismic performace of a 3-Story Ordinary Moment Resisting Concrete Frame
Fatigue and Structures & Materials
FHWA LRFD Steel Bridge Dec 2003
Fillet Weld Design welded connections
Formulas and references
Foundation Engineering Handbook
Foundations of Differential Calculus
Framed Fabric Structure Guidance
General Connections in Steel Buildings
Geotechnical Engineering Procedures for Foundation design of Buildings and Structures
Geotechnical Engineering Technical book
Guide to Design Criteria for Bolted & Riveted Joints
Handbook Differential Equations
Handbook of Comparative World Steel Standard
Handbook of Mathematical Formulas and Integrals
Handbook of Mathematics
NSCP-for-Windload
Numerical-Methods
Pre-Stressed-Precast-Concrete-Beam-Bridge-Design
Principles-and-Practices-of-Soil-Mechanics-and-Foundation-En
Probability-and-Statistics
project report-sample
Project-Tutorial-i
Project-Tutorial-2
Project-Tutorial-3
Project-Tutorial-4
PROKON TUTORIALS
Reinforced-Concrete-Analysis-and-Design
REINFORCED-CONCRETE-MECHANICS-AND-DESIGN
Residential-Structural-Design-Guide-2000-Edition
Retrofitting-of-Earthquake-Affected-Buildings-ppt
saudi-Building-Code-Requirements-for-Soils-and-Foundations
Section-2-Materials-and-Testina-of-Materials
Seismic-Conceptual-Design-of-Buildings
Seismic-Design-of-RC-Structures-Using-UBC-ACI-Provisions
Settlement-Analysis
Simple-Welded-Connections
Site-Planning-and-Design-Handbook
Staadpro-2007-International-Codes-2007-Complete
STAADpro-Examples-2006
Standard-Practice-for-Shotcrete-1
Steel-Design-Workin-Examples
Steel-Roof-Design-ASD
Steel-Sheet-Piles
Steel-Sheet-Piling-Design-Manual
Steel-Structures-Design-Lecture-O7-Simple-Welded-Connections
Steel-Structures-Practical-Design-Studies-2nd-T-J-MacGinley
Steelwork Design Guide to BS
Strength-of-Materials-Parts-I-II
Structural-Analysis
Structural-Analysis-in-Theory-and-Practice
Structural-Engineering-Handbooks-4-Structural-Concrete-Design-a-Girder
Structural-Method-of-Detailing-Structural-Concrete
Structural-Steelwork-Analysis-Design
Structural-Steelwork-Connections
Structural-Steelwork-Eurocodes
Structural-Vibration-Analysis-and-Damping
Structural-Welding-Code-Steel
T33 - Design of Fabric Structures-color handout
Tall-Building-Seismic-Analysis-Design
Tekla-import-from-staad-By-Engr-Atul-Saxena
The-Finite-Element-Method-in-Engineering-S-S-Rao
The-Management-of-Construction-A-Project-Lifecycle-Approach-Malestrom
thermodynamics-by-onkar-singh
Three-Dimensional-Static-and-Dynamic-Analysis-of-Structures
Timber-and-Timber-Trees
TIME-HISTORY-ANALYSIS-OF-REINFORCED-CONCRETE-FRAMED-BUILDINGS-ON-GEOSYNTHETIC-REIN...
Transmission-Line-Design
Transportation-Engineering
Truss-Design
[-] The following 2 users Like nassara's post:2 users Like nassara's post
  β€’ jokerβ„’, mkbreaker
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
04-14-2012, 09:55 PM (This post was last modified: 04-14-2012, 09:59 PM by usman.)
Here is the directory structure of above post
146 electronic files (names and sizes are shown below)
@nassara:
Nice sharing but not a good way of sharing (that's why this post is sitting in BAS POSTS section)
any user has to spent reasonable amount of time to download 1.39GB to get any desired book (which is not even named properly... so have to check each and every book first)
by the way most of the books are already available in the forum in their respective sections
17,978,248 bytes. . . 2003-International-Plumbing-Co.pdf
38,824,683 bytes. . . 3DS-Max-Tutorials.pdf
21,095,833 bytes. . . Aci-Design-Handbook.pdf
...627,173 bytes. . . ACI-Mix-Design-2.pdf
.2,069,706 bytes. . . Advanced-Mathematics.pdf
50,136,612 bytes. . . AISC ASD Manual 9th Edition.pdf
...110,606 bytes. . . Aisc-Asd89.pdf
...110,276 bytes. . . AISC-ASD-Column-Design.pdf
....57,145 bytes. . . AISC-Design-Guides.pdf
.2,544,096 bytes. . . Architecture-eBook-Design-for-Construction-SCI.pdf
10,905,687 bytes. . . Architecture-Ebook-Steel-Designers-Manual-6th-ed.pdf
...311,808 bytes. . . Arc-Welding.ppt
.1,234,432 bytes. . . ASCE705.Seismic.ppt
...793,600 bytes. . . ASD vs LRFD_ForWebSite.ppt
.4,091,988 bytes. . . Astm-Stainless-Steel.pdf
...635,594 bytes. . . Basic-Structural-Theory.pdf
...570,075 bytes. . . Basic-Structural-Theory-annotated.pdf
...122,571 bytes. . . Beam-Column-Base-Plate-Design.pdf
...474,419 bytes. . . Beam-Design-Formulas-With-Shear-and-Moment-Diagrams.pdf
.8,000,945 bytes. . . Bridge-Design-Manual-2006.pdf
.3,792,566 bytes. . . Bridge-Design-Using-STAAD.pdf
.6,405,003 bytes. . . Building-Design-Process.pdf
27,340,973 bytes. . . Calculus.pdf
11,212,145 bytes. . . Civil-Engineering-Hydraulics.pdf
...184,528 bytes. . . Code-of-Conduct-for-Professionals-in-Civil-Engineering.pdf
...518,878 bytes. . . Composite-Beam-Design.pdf
.1,132,645 bytes. . . Composite-Structures-of-Steel-and-Concrete.pdf
36,958,709 bytes. . . Concrete-Construction-Engineering-Handbook-2nd-Edition-2008-KMD.pdf
.2,383,527 bytes. . . Concrete-Example-SI.pdf
24,120,230 bytes. . . Concrete-Pavementmanual.pdf
17,511,228 bytes. . . Concrete-Pipe-Design-Manual.pdf
.3,582,888 bytes. . . Connections-HandBook-2002.pdf
.3,172,925 bytes. . . Construction-Handbook.pdf
13,435,501 bytes. . . Cranes-Design-Practice-And-Maintenance-Malestrom.pdf
...386,715 bytes. . . Curved-Beams.pdf
.3,857,966 bytes. . . decision-making-in-engineering-design.pdf
.3,492,282 bytes. . . design of fully restrained moment connections AISC LRFD 3rd Edition (2001).pdf
.8,880,046 bytes. . . Design-and-Construction 1.pdf
31,266,634 bytes. . . Design-and-Construction.pdf
...451,808 bytes. . . Design-and-construction-of-Concrete-Formwork.pdf
...646,392 bytes. . . Design-and-Construction-of-Driven-Pile-Foundation.pdf
...379,563 bytes. . . Design-of-Curved-Beams.pdf
.1,223,540 bytes. . . Design-of-Footings.pdf
...230,086 bytes. . . Design-of-Monorail-Systems.pdf
.2,377,530 bytes. . . design-of-pile-foundations.pdf
10,734,862 bytes. . . Design-of-Pre-Stressed-Concrete-Gilbert-Mikleborough.pdf
47,156,255 bytes. . . Design-of-Reinforced-Concrete-ACI-05-McCormac-J-C.pdf
.3,944,203 bytes. . . Design-of-Shear-Wall-Buildings.pdf
...666,128 bytes. . . Design-of-Steel-Footbridges-2005.pdf
.5,777,769 bytes. . . Design-of-Steel-Shelter-Final.pdf
.1,959,706 bytes. . . Design-of-Timber-Structures.pdf
.7,591,835 bytes. . . Design-Portal-Frame.pdf
.2,683,629 bytes. . . DIFFERENTIAL-EQUATIONS-Complete.pdf
18,538,590 bytes. . . dynamic-analysis.pdf
.1,772,921 bytes. . . Earthquake-Engineering-Analysis-and-Design.pdf
.6,910,583 bytes. . . Engineered-Plumbing-Design-II-ASPE-Dr-steel.pdf
.7,047,191 bytes. . . Engineering-Dynamics.pdf
39,734,284 bytes. . . Engineering-Economic-Analysis.pdf
52,157,520 bytes. . . Engineering-Fluid-Mechanics-9th-Edition.pdf
.9,774,976 bytes. . . EPRI-Manual-on-Estimating-Soil-Properties-for-Foundation-Design.pdf
.4,466,289 bytes. . . ETABS-Composite-Floor-Frame-Design-Manual.pdf
...351,442 bytes. . . Evaluation-of-the-seismic-performance-of-a-3story-ordinary-moment-resisting-concrete-frame.pdf
51,189,418 bytes. . . Fatigue-of-Structures-and-Materials.pdf
.3,142,664 bytes. . . FHWA-LRFD-steel-bridge-Dec2003.pdf
...181,837 bytes. . . Fillet-Weld-Design-Welded-Connections.pdf
...742,942 bytes. . . Formulas-and-References.pdf
31,473,623 bytes. . . Foundation-Engineering-Handbook.pdf
...901,466 bytes. . . Foundations-Of-Differential-Calculus-Euler.pdf
.1,104,486 bytes. . . Framed Fabric Structure Guidance.pdf
.3,647,073 bytes. . . General-Connections-in-Steel-Buildings.pdf
.3,247,364 bytes. . . Geotechnical-Engineering-Procedures-for-Foundation-Design-of-Buildings-and-Structures.pdf
.7,586,986 bytes. . . Geotechnical-Engineering-Technical-Book.pdf
.6,993,176 bytes. . . Guide-to-Design-Criteria-for-Bolted-And.pdf
.4,686,956 bytes. . . Handbook-Differential-Equations.pdf
.4,169,040 bytes. . . Handbook-Of Comparative World Steel Standard.pdf
.2,051,393 bytes. . . Handbook-of-Mathematical-Formulas-and-ntegrals.pdf
73,778,722 bytes. . . Hand-Book-of-Mathematics.pdf
16,315,834 bytes. . . Handbook-of-Plant-Engineering.pdf
40,776,130 bytes. . . Hearn-EJ-Mechanics-of-Materials.pdf
.8,687,574 bytes. . . Highway-Engineering-Handbook.pdf
.1,085,011 bytes. . . IBC1997UBC2000-Structural-Comparison-and-Cross-Reference.pdf
.1,374,188 bytes. . . IGirder.pdf
.1,114,657 bytes. . . In-Place-Methods-to-Estimate-Concrete-Strength.pdf
44,352,820 bytes. . . Internal-Combustion-Engines-Fundamentals-John-B-heywood.pdf
26,904,003 bytes. . . Materials-Engineers-Technicians.pdf
.4,461,253 bytes. . . Materials-Handbook.pdf
.8,564,747 bytes. . . Math-Adv-Calculus.pdf
.7,456,151 bytes. . . Math-Analysis.pdf
17,610,895 bytes. . . Math-Differential-Integral-Calculus-Theory.pdf
.1,848,562 bytes. . . Mathematical-Formulas-for-Economists.pdf
.5,799,961 bytes. . . MBMA 1996 Low-Rise-Building-Systems-Manual.pdf
.6,430,078 bytes. . . Nonlinear-Pushover-Analysis-of-Reinforced-Concrete-Structures.pdf
...335,991 bytes. . . NSCP-for-Windload.pdf
.8,748,802 bytes. . . Numerical-Methods.pdf
.5,801,233 bytes. . . Pre-Stressed-Precast-Concrete-Beam-Bridge-Design.pdf
60,930,281 bytes. . . Principles-and-Practices-of-Soil-Mechanics-and-Foundation-En.pdf
.1,520,667 bytes. . . Probability-and-Statistics.pdf
.6,105,107 bytes. . . project report-sample.pdf
.2,201,439 bytes. . . Project-Tutorial-1.pdf
.2,220,274 bytes. . . Project-Tutorial-2.pdf
.2,400,550 bytes. . . Project-Tutorial-3.pdf
.3,259,979 bytes. . . Project-Tutorial-4.pdf
.3,647,259 bytes. . . PROKON TUTORIALS.pdf
13,221,037 bytes. . . Reinforced-Concrete-Analysis-and-Design.pdf
53,418,826 bytes. . . REINFORCED-CONCRETE-MECHANICS-AND-DESIGN.pdf
.3,946,320 bytes. . . Residential-Structural-Design-Guide-2000-Edition.pdf
.7,504,234 bytes. . . Retrofitting-of-Earthquake-Affected-Buildings-ppt.pdf
...986,857 bytes. . . saudi-Building-Code-Requirements-for-Soils-and-Foundations.pdf
.1,340,892 bytes. . . Section-2-Materials-and-Testing-of-Materials.pdf
.2,797,715 bytes. . . Seismic-Conceptual-Design-of-Buildings.pdf
15,863,242 bytes. . . Seismic-Design-of-RC-Structures-Using-UBC-ACI-Provisions.pdf
.1,566,079 bytes. . . Settlement-Analysis.pdf
...696,433 bytes. . . Simple-Welded-Connections.pdf
12,343,102 bytes. . . Site-Planning-and-Design-Handbook.pdf
.5,432,313 bytes. . . Staadpro-2007-International-Codes-2007-Complete.pdf
.1,739,220 bytes. . . STAADpro-Examples-2006.pdf
.1,676,824 bytes. . . Standard-Practice-for-Shotcrete-1.pdf
.5,189,243 bytes. . . Steel-Design-Workin-Examples.pdf
.1,701,499 bytes. . . Steel-Roof-Design-ASD.pdf
.8,445,721 bytes. . . Steel-Sheet-Piles.pdf
.8,445,721 bytes. . . Steel-Sheet-Piling-Design-Manual.pdf
...696,433 bytes. . . Steel-Structures-Design-Lecture-07-Simple-Welded-Connections.pdf
.5,348,580 bytes. . . Steel-Structures-Practical-Design-Studies-2nd-T-J-MacGinley.pdf
25,280,185 bytes. . . Steelwork Design Guide to BS.pdf
34,150,364 bytes. . . Strength-of-Materials-Parts-I-II.pdf
14,322,952 bytes. . . Structural-Analysis.pdf
.3,602,522 bytes. . . Structural-Analysis-in-Theory-and-Practice.pdf
...885,893 bytes. . . Structural-Engineering-Handbooks-4-Structural-Concrete-Design-a-GRIDER-J-a-RAMIREZ-Y-M-YUN.pdf
11,177,134 bytes. . . Structural-Method-of-Detailing-Structural-Concrete.pdf
24,920,897 bytes. . . Structural-Steelwork-Analysis-Design.pdf
15,237,497 bytes. . . Structural-Steelwork-Connections.pdf
.4,606,148 bytes. . . Structural-Steelwork-Eurocodes.pdf
14,950,635 bytes. . . Structural-Vibration-Analysis-and-Damping.pdf
27,750,500 bytes. . . Structural-Welding-Code-Steel.pdf
.2,720,388 bytes. . . T33 - Design of Fabric Structures-color handout.pdf
.4,779,970 bytes. . . Tall-Building-Seismic-Analysis-Design.pdf
.1,219,111 bytes. . . Tekla-import-from-staad-By-Engr-Atul-Saxena.pdf
21,945,749 bytes. . . The-Finite-Element-Method-in-Engineering-S-S-Rao.pdf
13,369,314 bytes. . . The-Management-of-Construction-A-Project-Lifecycle-Approach-Malestrom.pdf
10,883,065 bytes. . . thermodynamics-by-onkar-singh.pdf
.3,273,609 bytes. . . Three-Dimensional-Static-and-Dynamic-Analysis-of-Structures.pdf
.8,845,556 bytes. . . Timber-and-Timber-Trees.pdf
...474,984 bytes. . . TIME-HISTORY-ANALYSIS-OF-REINFORCED-CONCRETE-FRAMED-BUILDINGS-ON-GEOSYNTHETIC-REINFORCED-SOIL.pdf
.7,574,568 bytes. . . Transmission-Line-Design.pdf
12,076,794 bytes. . . Transportation-Engineering.pdf
.4,999,590 bytes. . . Truss-Design.pdf
[-] The following 2 users Like usman's post:2 users Like usman's post
  β€’ oanm2000, kowheng
