Civil Engineering Association eBooks Journals, Papers and Presentations Global buckling analysis of plane and space thin-walled frames in the context of GBT
 yanburak
User ID: 27551
Threads: 74
Likes: 821 in 94 posts
Given Likes: 421
10-17-2010, 10:37 AM
Article: Global buckling analysis of plane and space thin-walled frames in the context of GBT
Thin-Walled Structures
Volume 46, Issue 1, January 2008, Pages 79-101
Abstract
This paper reports research work concerning the use of Generalised Beam Theory (GBT) to analyse the global buckling behaviour of
plane and space thin-walled frames. Following a brief overview of the main concepts and procedures involved in the performance of a
GBT buckling analysis, one presents in detail the formulation and numerical implementation of a GBT-based beam finite element that
includes only the first four (rigid-body) deformation modesβ€”namely, one describes (i) the kinematical models developed to simulate the
warping transmission at frame joints connecting two or more non-aligned U- and I-section members, (ii) the procedures adopted to
handle the effects stemming from the non-coincidence of the member centroidal and shear centre axes (cross-sections without double
symmetry), and (iii) the definition of joint elements, which involves providing a relation between the connected member GBT degrees of
freedom and the joint generalised displacements. Finally, one presents and discusses numerical results that make it possible to illustrate
the application and show the capabilities of the above GBT-based finite-element formulation and implementation. For validation
purposes, the GBT-based results (critical buckling loads and mode shapes) are also compared with values yielded by shell (mostly) and
beam finite element analyses carried out in the code ANSYS.
[-] The following 9 users Like yanburak's post:9 users Like yanburak's post
  β€’ kowheng, Dell_Brett, cargadory2k, oanm2000, jcbv, yly8, LiviuM, andersen3, fer962933
 yohanga
Zimbabwe
User ID: 13133
Likes: 5 in 2 posts
Given Likes: 15
04-05-2012, 03:20 PM
The link is dead
Could somebody reupload it?
[-] The following 1 user Likes yohanga's post:1 user Likes yohanga's post
  β€’ fer962933
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
04-05-2012, 03:51 PM
Dear yohanga
Here this paper is:
[-] The following 7 users Like ssobhan's post:7 users Like ssobhan's post
  β€’ sodapas, LiviuM, zrilek, Dell_Brett, yohanga, andersen3, fer962933
  Buckling of built-up compression members in the plane of the connectors asim99 2 7,263 12-12-2014, 04:39 PM
Last Post: Veggeta
  Some Remarks on the Seismic Demand Estimation in the Context of Vulnerability Assessm TAFATNEB 0 4,036 05-10-2014, 10:21 AM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 5,265 04-11-2014, 09:13 AM
  [ASCE] Buckling Analysis of a Long‐Span Roof Structure Collapsed during Construction mybest 1 6,175 04-08-2014, 11:35 AM
Last Post: Mohammad6299
  Performance-based plastic design method for buckling-restrained braced frames arshiakh 1 5,975 11-28-2013, 11:58 AM
  Plastic Buckling of Cylindrical Shells: A Theoretical Analysis and Comparison with Te asim99 0 3,959 05-04-2013, 03:33 PM
  Capacity interaction in brick masonry under simultaneous in-plane and out-of-plane lo arshiakh 0 3,881 04-24-2013, 07:10 PM
Last Post: arshiakh
