Civil Engineering Association eBooks Journals, Papers and Presentations SEISMIC RESPONSE MODIFICATION FACTORS by Andrew Whittaker
 neikrof
User ID: 12894
Threads: 1
Likes: 111 in 16 posts
Given Likes: 133
03-21-2012, 02:49 AM
Author: Andrew Whittaker, Gary Hart, and Christopher Rojahn, Members, ASCE | Size: 128 KB | Format: PDF | Quality: Original preprint | Publisher: Journal of Structural Engineering, Vol. 125, No. 4, April 1999, pp. 438-444 | Year: 1999 | pages: 7
The response modification factor plays a key role in the seismic design of new buildings in the United States. To date, the values assigned to this factor are based on engineering judgment and have little sound technical basis. Any improvement in the reliability of modern earthquake-resistant buildings in the United States will require the systematic evaluation of the building response characteristics that most affect the values assigned to the factor. To this end, a draft formulation that represents the response modification factor as the product of factors related to reserve strength, ductility, and redundancy is presented in the paper. Pertinent data from various analytical and experimental studies on reserve strength and ductility are also presented.
[-] The following 15 users Like neikrof's post:15 users Like neikrof's post
  â€¢ kowheng, mehabb, malc, triance, farahshaheen47, Dell_Brett, Jackass, subin91, ebaturalp, ruaumoko, engrezi, ISTRAKTURA, gulilero, DamaD, fred2010
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 5,828 02-12-2015, 01:39 PM
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,047 12-26-2014, 09:49 PM
  Seismic response of earth dams: some recent developments TAFATNEB 0 4,401 08-12-2014, 09:33 AM
  RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE TAFATNEB 0 5,205 08-10-2014, 01:15 PM
  RISK ASSESSMENT USING SEISMIC RISK MANAGEMENT AND RESPONSE ANALYSIS OF BASE ISOLATION TAFATNEB 0 4,569 12-20-2013, 09:05 AM
  Seismic response of steel frames containing hierarchical frictiondissipating joints TAFATNEB 1 5,093 11-28-2013, 12:08 PM
  Pushover and Seismic Response of Foundations on Stiff Clay: Analysis with P-Delta Eff TAFATNEB 0 4,063 11-23-2013, 11:32 PM
