Civil Engineering Association eBooks Structural Books Concrete ECONOMIC LONG SPAN CONCRETE FLOOR SLABS
 gboyega
User ID: 2845
Threads: 33
Likes: 711 in 38 posts
Given Likes: 27
08-25-2009, 06:47 AM (This post was last modified: 01-24-2011, 11:58 AM by oanm2000.)
[Image: twotyxxlf0xx5hf8nd5u.jpg]
Traditional concrete designs for office building have been associated with either beam and slab or flat slab floors, typically with 6 to 7.5 m spans. Occasionally, longer-span floors have been designed using ribbed or waffle construction. In recent times, changes in the requirements of end-users and in developers’ specifications have led to more open-plan offices and larger floors. This has increased spans from 6 to 9 m, even to 15 m and more.
To verify the competitiveness of concrete long-span floors, a survey has been conducted of concrete-framed office buildings, the majority constructed in recent years. Forty buildings of in situ, precast and composite construction with long spans have been surveyed. In each category, examples were found of floors designed in reinforced and prestressed concrete to carry similar office
floor loadings.
For in situ structures, solid flat slabs and ribbed slab designs were common, with spans varying from 6 to 15 m. A number of precast structures with long spans, some over 20 m, are reported, with composite in situ slabs acting with precast ribs or other precast members.
Download Links:
[-] The following 59 users Like gboyega's post:59 users Like gboyega's post
  • concreteok, concreteok, vvvv, vvvv, abudabeeja, abudabeeja, Dell_Brett, Dell_Brett, essam2109, essam2109, paulocs, paulocs, nuttapolk, nuttapolk, zrilek, zrilek, rendel_©, rendel_©, chenamoy, chenamoy, cristi, cristi, Grunf, Grunf, zego2000, zego2000, i_kabir, i_kabir, Yasir, Yasir, baikur, baikur, michaelsoe, michaelsoe, muki5, KAMM, tang1942, bubieng, sodapas, highcivil, ssi3k, mayur_patil, blaze, jf28, toa011, kg85arun, Adam Smith, henrycv, mecheil.edwar, oanm2000, DamaD, Trishu999, Nilupa, tazmania, bhuiyan, thebeatles, malc, narendra, jcoronellr
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Likes: 4,964 in 638 posts
Given Likes: 3501
08-25-2009, 07:09 AM (This post was last modified: 01-23-2011, 07:53 PM by Grunf.)
P.W. Matthew BE, MSc, MIE(Aust)
D.F.H. Bennett BSc, MSc, CEng, MICE
First published 1990
Reprinted 1994, 1995
ISBN 0721013864
British Cement Association
47p
[-] The following 14 users Like concreteok's post:14 users Like concreteok's post
  • paulocs, paulocs, zrilek, zrilek, Grunf, Grunf, Yasir, Yasir, arunsmt, Dell_Brett, kg85arun, mecheil.edwar, oanm2000, thebeatles
01-23-2011, 07:55 PM
Direct link:
[-] The following 15 users Like Grunf's post:15 users Like Grunf's post
  • Dell_Brett, toa011, kg85arun, kowheng, usman, mecheil.edwar, miquan, vardan, hans01, oanm2000, zrilek, yanburak, Dorogon, thebeatles, Trishu999
  Design of prestressed Concrete flat slabs tuanpecc1 5 5,245 12-09-2021, 07:59 AM
Last Post: Gabemzaman
  Guide to Long-Span Concrete Floors rendel_© 1 2,871 02-17-2020, 02:36 PM
Last Post: malee
  Behaviour Of Reinforced Concrete Flat Slabs mowafi3m 3 4,196 07-19-2018, 12:38 PM
Last Post: febo927
  Guide to the design and construction of reinforced concrete flat slabs gulilero 3 3,786 04-14-2018, 09:08 AM
Last Post: gianniorlati
  Ground Bearing Concrete Slabs rami1976 0 1,687 05-21-2016, 01:11 PM
  Reinforced Concrete Slabs - Park, T. and Gamble, W., By Wiley, 2nd sheb101 12 8,370 04-13-2015, 03:10 AM
Last Post: concreteok
  Designing Floor Slabs on Grade - by Boyd C Ringo and Robert B Anderson usman 5 5,277 02-02-2015, 02:11 PM
Last Post: Veggeta
