Civil Engineering Association eBooks Structural Books Steel COMMENTARY AND WORKED EXAMPLES TO EN 1993-1-5 “PLATED STRUCTURAL ELEMENTS”
Threads: 1,298
03-01-2011, 06:42 AM
Author: B. Johansson, R. Maquoi, G. Sedlacek, C. Müller, D. Beg | Size: 4.28 MB | Format: PDF | Publisher: JRC – ECCS | Year: 2007 | pages: 242 | ISBN: ISSN 10185593
[Image: 26365754940718141586.jpg]
The objective of this commentary is to present the scientific background to the rules. The mechanical models behind the rules are presented and references to source documents are given. All such models include simplifications, which have to be justified by calibration of the rules against test results. Several models for each failure mode have been checked with calibrations according to Annex D of EN 1990 [2] and the ones included in EN 1993-1-5 are those giving the lowest scatter and the most uniform safety. The procedure for calibration will be summarised in section 1.2. It should be noted that EN 1993-1-5, being a generic code, does not suggest γM values. According to the Eurocode system these values depend on the specific application and should be given by application parts e.g. for buildings in EN 1993-1-1 [3] and bridges in EN 1993-2 [4].
Although the rules may look unfamiliar to many engineers they are in fact only a new combination of rules from different European countries. For the time being they represent a set of useful rules for common plated structures. The intention is to cover beam type of structures like I-girders and box-girders. There are also details that may be improved by further research and some indications are given in this commentary.
This commentary is organised mainly in the same way as the code. In the right hand margin of the pages there are references to the specific clause in the code that the text refers to. The section headings follow that of the code but sometimes related rules from other sections are dealt with together with the main topic of the section. References to literature are given in the end of each section. Some sections go quite far into detail with the intention of documenting unpublished work with development of design rules during the drafting of the code. This commentary is not an official document from CEN but a private initiative by the authors. The content of commentary expresses the opinion of the author of each section although the content has been reviewed within the group. This applies also to clarifications and interpretations of the code. In addition to giving background information to the sections of EN 1993-1-5 this commentary also presents some worked examples in Section 15, 16 and 17. They show how the rules of the code can be applied in practical design.
[-] The following 25 users Like ir_71's post:25 users Like ir_71's post
  • kowheng, blaze, cve_jule, melkat, lucky_b2me, Dell_Brett, vvvv, Grunf, vardan, tamboon, rezart, toa011, seriousboy, chenamoy, Quantumm, oanm2000, zrilek, foxxx2010, andersen3, jferrer, giga, Clouseau, Nilupa, kmmh76, yanburak
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
06-08-2012, 07:53 AM (This post was last modified: 06-08-2012, 07:54 AM by ssobhan.)
Direct link:
[-] The following 11 users Like ssobhan's post:11 users Like ssobhan's post
  • malc, stosto6666, david-smith, slowet, chrono146, zrilek, Jackass, lisine, ruaumoko, cristi, wanwin
07-31-2012, 06:21 AM
Direct Links :Wink
[-] The following 2 users Like shadabg's post:2 users Like shadabg's post
  • cace-01, gulilero
  Ultimate Limit State Design of Steel-Plated Structures apocalipse 2 3,156 11-19-2020, 03:16 PM
Last Post: Kurucz
  Steel Building Design: Worked examples for students rami1976 0 1,966 11-12-2015, 10:39 PM
  Design of Plated Structures hich 2 3,696 10-19-2015, 05:06 PM
Last Post: ibg0203
  Behaviour and Design of Steel Plated Structures Bmartin 2 3,441 11-06-2014, 02:57 AM
Last Post: concreteok
  Steel Plated Structures amindoxiti 0 1,791 09-11-2014, 02:36 AM
  Steel Building Design: Worked Examples – Open Sections (SCI P364) jamildear4u 5 4,742 12-17-2013, 02:04 PM
  SCI P376 - Steel Building Design: Worked Examples for Students jamildear4u 3 2,697 10-13-2013, 08:38 AM
Last Post: vinnunsam
