Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive Finite Element Modeling of Wrap-Around Gusset Plates in Tension
 michenerpark
Member
China
User ID: 14276
Threads: 5
Likes: 98 in 27 posts
Given Likes: 11
01-04-2011, 03:19 AM (This post was last modified: 01-04-2011, 10:45 PM by Dell_Brett.)
Anyone can downlaod this for me
by Bo Dowswell, Robert Whyte, Jim Davidson, and Fouad Fouad
Document type: Conference Proceeding Paper
Part of: 2006 Structural Engineering and Public Safety
Abstract: Gusset plates are used in steel buildings to connect bracing members to other structural members in the lateral force resisting system. Horizontal bracing is commonly used to resist lateral loads in industrial structures and in commercial buildings where floor and roof diaphragms cannot carry the loads. Wrap-around gusset plates are L-shaped plates that are used where an opening is required at the comer of the plate. This typically occurs at horizontal bracing where the gusset plate is cut out around a column. Finite element models were used to determine the behavior of wrap-around gusset plates. The plates were modeled using material and geometric nonlinearities. Five different gusset plates were modeled with geometry and material properties matching the experimental specimens of Dowswell. All of the models were loaded in tension. The loads from the finite element models were compared to the experimental loads.
Thanks in advance
  [REQUEST] Geometric Formulas for Gusset Plate Design carolinandra 3 4,644 01-04-2022, 11:55 AM
  [REQUEST] Introduction to Approximate Solution Techniques, Numerical Modeling, & Finite Element freequo 2 2,512 05-27-2019, 04:32 PM
  [REQUEST] Finite-Element Modelling of Unbounded Media amindoxiti 0 1,537 04-30-2018, 12:57 PM
  [REQUEST] Reliability assessment using stochastic finite element analysis apocalipse 0 1,500 07-31-2017, 09:22 AM
Last Post: apocalipse
  [REQUEST] Benefits derived from use of 3D finite element analysis in the design of deep excavat PIGAS 1 1,867 09-16-2014, 10:53 AM
Last Post: PIGAS
  [REQUEST] Finite Element Analysis: Theory and Application with ANSYS (4th Edition) mastermind 1 1,939 08-07-2014, 10:54 AM
Last Post: trmpereira
  [REQUEST] Finite Element Simulations Using ANSYS tolga 0 1,541 04-15-2014, 07:14 PM
Last Post: tolga
