Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive Design of urban water distribution Network
 wafiullah
User ID: 24367
Threads: 28
Likes: 542 in 44 posts
Given Likes: 88
08-06-2010, 07:00 PM
Hello,
I would be immensly grateful if someone could assist me in Designing Guidlines and Procedure for Urban Water Supply Network.
I am Particularly Intersted in Providing the Designed sheets for Hydraulic pipline and relevent Hydraulic structures
Best Regards
 chigozie
User ID: 5921
Threads: 18
Likes: 657 in 257 posts
Given Likes: 1548
08-07-2010, 10:54 AM
Use google search to locate and download EPANET. Read the manual and try the tutorials. You will also get other usefull information at same site.
Good luck
Teddy
 ska51
User ID: 11535
Threads: 427
Likes: 9,406 in 1,251 posts
Given Likes: 4017
08-07-2010, 06:24 PM
In response of post#2,
Yeah, EPANET is a free and nice software for working in hydraulic modeling of pipeline and many more in water supply sector.
In this connetion, I would like to add that this forum does also contain some sorts of other similar softwares relevant to working in water supply like BossStormNet, WaterCAD etc.
Also, I would suggest to use SWMM model to work for urban water management system. All the best.
"Downstream is Weaker"
[-] The following 1 user Likes ska51's post:1 user Likes ska51's post
  • itsme85
 hazus
Tunisia
User ID: 21462
Threads: 80
Likes: 781 in 104 posts
Given Likes: 225
08-07-2010, 07:43 PM
Hello all, I want to add also cype 2011b posted by Benny.P, wich contain a module for such design.
But let's start with data needed for design:
1- hourly average demand (projected number of citizen*demand per citizen)
2- daily and hourly pic coefficient
3- fire stations positions
4- network to be designed
5- tank position
Then you calculate
1- pic hourly demand Qphd,
2- specific flow Qsf=Qphd/TOT lenghth of network
3- demand flow per pipe : Qfp=Qsf*L (pipe)
4- demand in the nodes assuming that every pipe will offer 50% in the beginning and 50% in the end
All this calculation is necessary to apply hardy cross method to calculate diameter, pressure, flows, velocity, tank elevation, pumps...
[-] The following 2 users Like hazus's post:2 users Like hazus's post
  • itsme85, chigozie
 chigozie
User ID: 5921
Threads: 18
Given Likes: 1548
09-06-2010, 09:33 AM
ska51 wrote:-
……working in water supply like BossStormNet, WaterCAD etc…… I would suggest to use SWMM model to work for urban water
management system. ……..
Comment:-
Please not that BossStormNet and SWMM are not for the design of water supply network. They are for storm, sewage and wastewater systems’ design/management.
hazus wrote:-
…..Then you calculate 1- pic hourly demand Qphd, 2- specific
flow Qsf=Qphd/TOT lenghth of network 3- demand flow per
pipe : Qfp=Qsf*L (pipe) 4- demand in the nodes assuming that
Comment:- That’s a good and an elaborate guide.
If you are using any of the software (at least EPANET), you do not have the need to calculate most of the parameters as enumerated above. You only have to establish your demand, the positions, elevations, the appurtenances of the your network and the software will do the rest. For a beginning, it would be very useful to evaluate the parameters enumerated above as to have a feel of the design(though not necessary as to get the programmes running).
Teddy
  • ska51
  [REQUEST] Urban Hydrology and Hydraulic Design noelda2 0 1,474 05-29-2011, 01:20 AM
Last Post: noelda2
  Bus network design VietTho 0 1,257 05-14-2010, 06:23 AM
Last Post: VietTho
