Civil Engineering Association Software Software Product Csi Products ETABS CSI ETABS V8
CSI ETABS V8
 falconado
User ID: 24
Threads: 11
Likes: 108 in 21 posts
Given Likes: 277
12-03-2009, 09:30 PM
CSI ETABS V8.45 NL
[Image: 68259143487106929872.jpg]
Hi friends,
This etabs version running suppper. try it.
Good works.
Falconado
TURKEY
No pass :clap::clap:
[-] The following 6 users Like falconado's post:6 users Like falconado's post
  â€¢ zrilek, ruaumoko, kerenski_t, wa_sin_29, dshiva, bigone
 falconado
User ID: 24
Threads: 11
Given Likes: 277
12-05-2009, 07:03 AM (This post was last modified: 12-05-2009, 08:29 AM by kowheng.)
CSI ETABS V8.5 NONLINEER
Dear friends,
This version is most commonly used by general CSI users. Good works. Use it..
falconado
[Image: 12517753764614233970.jpg]
For nearly 30 years ETABS has been recognized as the industry standard for
Building Analysis and Design Software. Today, continuing in the same
tradition, ETABS has evolved into a completely Integrated Building Analysis
and Design Environment. The System built around a physical object based
graphical user interface, powered by targeted new special purpose algorithms
for analysis and design, with interfaces for drafting and manufacturing, is
redefining standards of integration, productivity and technical innovation.
The integrated model can include Moment Resisting Frames, Braced Frames,
Staggered Truss Systems, Frames with Reduced Beam Sections or Side Plates,
Rigid and Flexible Floors, Sloped Roofs, Ramps and Parking Structures,
Mezzanine Floors, Multiple Tower Buildings and Stepped Diaphragm Systems
with Complex Concrete, Composite or Steel Joist Floor Framing Systems.
Solutions to complex problems such as Panel Zone Deformations, Diaphragm
Shear Stresses, and Construction Sequence Loading are now at
fingertips.
ETABS is the solution, whether you are designing a simple 2D frame or
performing a dynamic analysis of a complex high-rise that utilizes
non-linear dampers for inter-story drift control.
__________________________________________________
Moderator notes: Transparent link, code tag was added at this time
[Image: 46383483516136333604.gif]
Link belove.. No pass is need.
  â€¢ zrilek, kerenski_t, narendra, redtony, tang1942, bigone
