Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI 228.1: Report on Methods for Estimating In-Place Concrete Strengt
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
12-14-2024, 01:23 PM
ACI PRC-228.1-19: Report on Methods for Estimating In-Place Concrete Strengt
| Size: 27.23 MB| Format: PDF| Quality: Scanner| Year: 2019| pages: 48
[Image: 82850386453878542083.jpg]
This report provides methods for estimating the in-place strength of concrete in new and existing construction. These methods include: rebound number, penetration resistance, pullout, pull-off, ultrasonic pulse velocity, maturity, and cast-in-place cylinders. The principle, inherent limitations, and repeatability of each method are reviewed. Procedures are presented for developing the relationship needed to estimate compressive strength from in-place results. Factors to consider in planning in-place tests are discussed, and statistical techniques to interpret test results are presented. The use of in-place tests for acceptance of concrete is introduced. The Appendix A provides information on the number of strength levels that should be used to develop the strength relationship and explains a regression analysis procedure that accounts for error in both dependent and independent variables.
Keywords: coefficient of variation; compressive strength; construction safety; in-place tests; nondestructive tests; sampling; statistical analysis.
  â€¢ babakfeyzi, zrilek, lisine
  [CivilEA Exclusive] ACI 303: Cast-in-Place Architectural Concrete Practice Administrator 0 692 07-21-2026, 10:11 AM
Last Post: Administrator
  [CivilEA Exclusive] ACI 334.3: Construction of Concrete Shells Using Inflatable Forms - Report poolmand 0 1,438 12-14-2024, 01:04 PM
  ACI E702.3: Designing Concrete Structures: Acceptance of Concrete Compressive Strengt poolmand 0 1,434 08-27-2024, 11:07 AM
  [CivilEA Exclusive] ACI 308.1: External Curing of Cast-in-Place Concrete poolmand 1 2,111 02-03-2024, 06:32 AM
  [CivilEA Exclusive] ACI 327.1: In-Place Density Testing of Freshly Placed Roller-Compacted Concrete by Nu poolmand 0 1,549 10-31-2023, 07:59 AM
  ACI 370: Report for the Design of Concrete Structures for Blast Effects er.shyams 1 2,756 05-09-2023, 09:25 AM
  ACI 445.1: Report on Torsion in Structural Concrete Mohammad6299 3 3,302 05-08-2023, 07:15 AM
