Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI E702.9: Designing Concrete Structures: Reinforced Rectangular Concrete Column Int
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
08-28-2024, 06:13 AM
ACI E702.9-22 Designing Concrete Structures: Reinforced Rectangular Concrete Column Interaction Diagram Example
Author(s)/Editor(s): ACI Committee E702| Format: PDF| Quality: Original preprint| Year: 2022| pages: 14
[Image: 91975928942876088911.png]
This design example, β€œReinforced Rectangular Concrete Column Interaction Diagram Example,” works through the procedure to draw an interaction diagram for a 16 x 12 in. nonslender tied column reinforced with six No. 8 vertical bars and No. 3 ties at 12 in. on center bending around its x-axis. The example follows the provisions of ACI 318-19, Building Code Requirements for Structural Concrete.
ACI Committee E702, β€œDesigning Concrete Structures Committee,” is part of the ACI Educational Committee structure. Their mission is to develop educational programs and instructional materials within the area of design. The committee has developed various design examples to illustrate the use of various ACI documents. These examples provide step-by-step calculations with references to applicable code provisions for common member design problems, and may also include calculations for common concrete testing procedures, field data analysis, or evaluations.
  β€’ babakfeyzi
  [CivilEA Exclusive] ACI 447.2: Nonlinear Finite Element Analysis of Reinforced Concrete Beams, Columns, a poolmand 0 469 05-30-2026, 09:10 AM
  [CivilEA Exclusive] ACI PRC-440.14-25: Design of Circular Concrete-Filled Fiber-Reinforced Polymer Tubes poolmand 0 2,384 08-17-2025, 10:25 AM
  [CivilEA Exclusive] ACI SP-365: Modeling and Performance Assessment of Concrete Structures poolmand 0 2,697 04-19-2025, 12:54 PM
  [CivilEA Exclusive] ACI 440.13: Strengthening Structural Concrete with Fiber-Reinforced Polymer (FRP) Sys poolmand 0 2,003 12-15-2024, 06:43 AM
  [CivilEA Exclusive] ACI 349: Code Requirements for Nuclear Safety Related Concrete Structures andersen3 5 6,174 12-15-2024, 06:33 AM
  [CivilEA Exclusive] ACI 357: Design and Construction of Fixed Offshore Concrete Structures poolmand 0 1,873 12-14-2024, 01:11 PM
  ACI E702.8: Designing Concrete Structures: Evaluation of Concrete Cores Test Results poolmand 0 1,501 08-28-2024, 06:12 AM
