Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA B100: Granular Filter Material
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
01-15-2024, 11:41 AM (This post was last modified: 01-15-2024, 12:12 PM by poolmand.)
AWWA B100-16 Granular Filter Material
| Size: 15.8 MB| Format: PDF| Quality: Scanner| Year: 2016 | ISBN: 9781625761538
[Image: 86449853361038297833.jpg]
This standard describes gravel, high-density gravel, silica sand, high-density media, anthracite filter materials, and the placement of the materials in filters for water supply service application. ANSI/AWWA B604, Standard for Granular Activated Carbon, addresses use of GAC as a filter medium and as an adsorbent.
This standard describes gravel, high-density gravel, silica sand, high-density media, anthracite filter materials, and the placement of the materials in filters for water supply service application. ANSI/AWWA B604, Standard for Granular Activated Carbon, addresses use of GAC as a filter medium and as an adsorbent. Major revisions made to the standard in this edition include the following: added definition of anthracite in accordance with ASTM D388; added Table 7 to clarify maximum sample sizes allowed on individual sieves during sieve analysis; added references within Appendix A-Bibliography; added Appendix C with language related to particle size distribution classification that was in the foreword of the previous revision to the standard; and, added Appendix D with language related to Filter Media Support Gravel Size and Layer Depth that was in the foreword of the previous revision
  â€¢ PinkPant, babakfeyzi
  AWWA B101: Precoat Filter Media poolmand 0 1,527 01-15-2024, 12:16 PM
