Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
01-15-2024, 10:06 AM
ASTM C1518-22: Standard Specification for Precured Elastomeric Silicone Joint Sealants
| Size: 1.41 MB| Format: PDF| Quality: Scanner| Year: 2022| pages: 3
[Image: 45958073117037904709.jpg]
This specification describes the properties of applied, flat shaped precured elastomeric silicone joint sealants that bridge joint openings and are adhered to joint substrates utilizing a liquid applied silicone adhesive sealant to seal building openings such as panel joints, metal flashing joints, or other building openings in place of conventional liquid applied sealants. Seals are applied in three different configurations, as follows: as a bridge joint, the seal is applied flat on the surface to cover a joint opening; as a beveled bridge joint, the seal is applied on the beveled edge of a substrate to bridge a joint opening.; as a U-joint, the seal is applied in a U-configuration within a joint. Seals are classified into Movement Classes on the basis of movement capability, and Tear Class on the basis of tear propagation. Seals should adhere to specified requirements as to stability, color and texture, application, adhesion and cohesion, and movement, modulus, and tear characteristics.
  â€¢ babakfeyzi, PinkPant
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,102 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,433 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,216 01-15-2024, 10:13 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,491 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,563 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 3,099 10-28-2023, 06:32 AM
