01-26-2022, 05:56 AM
Guide for the Development of Bicycle Facilities
| Size: 2.7 MB| Format: PDF| Quality: Original preprint| Publisher: AASHTO| Year: 4th Edition, 2012| pages: 201 | ISBN: 1560515279 , 9781560515272
![[Image: 41360930903200488271.png]](https://pic.civilea.com/images/41360930903200488271.png)
This guide provides information on how to accommodate bicycle travel and operations in most riding environments. It is intended to present sound guidelines that result in facilities that meet the needs of bicyclists and other highway users. Sufficient flexibility is permitted to encourage designs that are sensitive to local context and incorporate the needs of bicyclists, pedestrians, and motorists. However, in some sections of this guide, suggested minimum dimensions are provided. These are recommended only where further deviation from desirable values could increase crash frequency or severity. This guide has been updated from the previous guide published in 1999. The fact that new guidance is presented herein does not imply that existing bicycle facilities are inadequate or unsafe, nor does it mandate the initiation of improvement projects. The intent of this document is to provide guidance to designers and planners by referencing a recommended range of design values and describing alternative design approaches.
Content:
Front Matter
• List of Figures
• List of Tables
• Table of Contents
1. Introduction
2. Bicycle Planning
3. Bicycle Operation and Safety
4. Design of On-Road Facilities
5. Design of Shared Use Paths
6. Bicycle Parking Facilities
7. Maintenance and Operations
Index
