Civil Engineering Association Software Software Product Csi Products ETABS CSI ETABS V20
CSI ETABS V20
 Arigato
Ireland
User ID: 740
Threads: 29
Likes: 893 in 88 posts
Given Likes: 277
01-12-2022, 09:30 AM (This post was last modified: 10-02-2023, 10:57 AM by Administrator.)
CSI ETABS v20.0.0
[Image: 65960817591503408080.png]
Related Link:
Abstract: Extended Three-Dimensional Analysis of Building Structures
[Image: comments.png]
Setup Only, No Medicine
[-] The following 21 users Like Arigato's post:21 users Like Arigato's post
  β€’ Administrator , temp1366, babakfeyzi, Dell_Brett, oanm2000, RajaK, simanta, caifan, zrilek, PinkPant, mowafi3m, cace-01, golpesar, strengbas, Wijono, Ekkaia, jaks, Josip15, jcbv, TAFATNEB, narendra
 RajaK
Structural Engineer
User ID: 172894
Threads: 8
Likes: 273 in 21 posts
Given Likes: 332
01-13-2022, 04:01 AM
Here is Patch, Thanks to LavTeam
[-] The following 23 users Like RajaK's post:23 users Like RajaK's post
  β€’ simanta, pezhmankhan, temp1366, caifan, zrilek, Dell_Brett, PinkPant, babakfeyzi, mowafi3m, cace-01, Administrator , kirankumarklk, taifur, oanm2000, golpesar, strengbas, Wijono, amiboyz, Ekkaia, jaks, kowheng, TAFATNEB, narendra
 skyscraper
User ID: 15267
Threads: 4
Likes: 68 in 28 posts
Given Likes: 91
02-19-2022, 07:02 AM (This post was last modified: 02-19-2022, 08:58 AM by Dell_Brett. Edit Reason: N/A )
Hi All
Does anyone know kg file pop up Win Lincense and request enter username and password? What is it? Thanks
[hr}
MODERATOR NOTE:
ItΒ΄s strongly necessary read carefully the LAVteam.nfo file!
ItΒ΄s a complex process do apply the license! And, yes! During this process you needs to input specific Name and Password inside!
Β  Β  Instructions: Unrar and install the application.
Delete created by default .net native image.
Run as admin command prompt (cmd.exe) and execute command:
C:\Windows\Microsoft.NET\Framework64\v4.0.30319>ngen uninstall ETABS
or
<installdir>\CSiNativeImageGen.exe -> F4 -> F4
Run \patch\etabs_v20_kg.exe
Password: B726F8F2-AE11F2E9-D43CB5FF-8080FC2D
A license file (lservrc) will be generated.
Copy both generated above license and applied
emulator (SentinelRMSCore.dll) to the folders:
<installdir> and <installdir>\CSiLicensing\
NOTE_0: allow program's access to the
internet otherwise program will not even start.
NOTE_1: you can try to replace SentinelRMSCore.ni.dll
besides deleting native image - program will start
much faster. But the good result is not guaranteed.
The program may not even start. On what does the
success depend on is a big question at the moment.
So replace
C:\Windows\assembly\NativeImages_v4.0.30319_64\SentinelRMSCore\bla-bla-bla(depends on product)\SentinelRMSCore.ni.dll
with \patched\SentinelRMSCore.ni.dll
NOTE_2: do not use Windows Explorer for
replacing SentinelRMSCore.ni.dll. No chance to
do this with it. Use Total Commander (for
example) with turning on option for showing
hidden files.
NOTE_3: for using Chinese codes copy file
\patch\level.txt to the <installdir>
[-] The following 4 users Like skyscraper's post:4 users Like skyscraper's post
  β€’ cace-01, Ekkaia, jaks, mowafi3m
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
04-01-2022, 02:36 PM
CSI ETABS v20.1.0
Related Link:
Setup Only, No Medicine (use old keygen v20.0)
No limits to creativity
[-] The following 10 users Like jokerβ„’'s post:10 users Like jokerβ„’'s post
  β€’ babakfeyzi, Dell_Brett, simanta, zrilek, cace-01, Administrator , PinkPant, KMABD, oanm2000, mowafi3m
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
04-10-2022, 10:25 AM (This post was last modified: 04-11-2022, 05:00 AM by Administrator.)
CSI ETABS v20.1.0 + KG
[-] The following 10 users Like poolmand's post:10 users Like poolmand's post
  β€’ Dell_Brett, oanm2000, jcbv, jokerβ„’, PinkPant, cace-01, Wijono, mowafi3m, ibmarin, rendel_Β©
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Likes: 626 in 97 posts
Given Likes: 1390
07-02-2022, 12:16 PM
Hi
CSI ETABS v20.2.0
[-] The following 2 users Like babakfeyzi's post:2 users Like babakfeyzi's post
  β€’ zrilek, mowafi3m
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
07-02-2022, 12:31 PM (This post was last modified: 07-02-2022, 12:32 PM by jokerβ„’.)
CSI ETABS v20.2.0
Related Link:
[-] The following 6 users Like jokerβ„’'s post:6 users Like jokerβ„’'s post
  β€’ golpesar, Dell_Brett, temp1366, zrilek, PinkPant, mowafi3m
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
07-26-2022, 05:36 AM
CSI ETABS v20.3.0
Related Link:
[-] The following 12 users Like jokerβ„’'s post:12 users Like jokerβ„’'s post
  β€’ babakfeyzi, Dell_Brett, zrilek, PinkPant, Williams, rami1976, ascetic19, cace-01, cargadory2k, oanm2000, KMABD, jaks
 skyscraper
User ID: 15267
Threads: 4
Given Likes: 91
08-18-2022, 03:54 AM
Hi
Is there anyone having an issue to install Etabs ver 20 on Windows 11? It is required me to enter activation code.
Thanks
  β€’
Threads: 758
Given Likes: 91
#10
09-04-2022, 11:40 AM (This post was last modified: 09-04-2022, 11:41 AM by poolmand.)
CSI ETABS v20.3.0 Build 2929 x64
  β€’ Dell_Brett, cace-01, rami1976, PinkPant, jokerβ„’, zrilek, subin91, lasalleguy, TAFATNEB
