Civil Engineering Association Forum Discussion Suggestion & Complains CivilEA Bug Report
CivilEA Bug Report
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,197 in 2,356 posts
Given Likes: 4260
#81
06-08-2019, 08:35 AM
(06-03-2019, 07:23 AM)rami1976 Wrote: this is an example
This is not bug, because the user put thumbnails picture, I edited it.
[-] The following 2 users Like Administrator 's post:2 users Like Administrator 's post
  â€¢ rami1976, oanm2000
 amindoxiti
User ID: 86739
Threads: 192
Likes: 8,341 in 584 posts
Given Likes: 2618
#82
07-02-2019, 10:52 AM (This post was last modified: 07-02-2019, 10:58 AM by amindoxiti. Edit Reason: N/A )
<p><span id="sceditor-start-marker" class="sceditor-selection sceditor-ignore" style="display: none; line-height: 0;"> </span><span id="sceditor-end-marker" class="sceditor-selection sceditor-ignore" style="display: none; line-height: 0;"> </span><br></p>
I wanted to report that something goes wrong and there are two extra lines at the beginning of each post, but when I opened the report page I saw that the lines were in the message box already as the above.
One more thing, the delete button still doesn't work for me, I use different browser but there is no difference.
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater.  -Albert Einstein
[-] The following 3 users Like amindoxiti's post:3 users Like amindoxiti's post
  â€¢ usman, jokerâ„¢, Dell_Brett
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
#83
07-02-2019, 11:51 PM
<span id="sceditor-start-marker" class="sceditor-selection sceditor-ignore" style="display: none; line-height: 0;"> </span><span id="sceditor-end-marker" class="sceditor-selection sceditor-ignore" style="display: none; line-height: 0;"> </span>The same:
[Image: 74564983978219645730.jpg]
  â€¢ usman, amindoxiti, lisine, oanm2000
 amindoxiti
User ID: 86739
Threads: 192
Given Likes: 2618
#84
08-07-2019, 04:25 PM (This post was last modified: 08-07-2019, 04:26 PM by amindoxiti.)
The problem which I reported still exists, any news?
[-] The following 2 users Like amindoxiti's post:2 users Like amindoxiti's post
  â€¢ Dell_Brett, oanm2000
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Given Likes: 4260
#85
08-10-2019, 08:43 AM
(08-07-2019, 04:25 PM)amindoxiti Wrote: The problem which I reported still exists, any news?
this is new bug from MYBB that I solved it today.
  â€¢ amindoxiti
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1388
#86
12-25-2019, 08:42 PM
Dear Admin
I tried to delete a post , as requested by our user mowafi3m , the delete command after marking the post to delete , is directing me to edit the post ( tried on both Microsoft Edge and Google chrome)
[-] The following 1 user Likes rami1976's post:1 user Likes rami1976's post
  â€¢ amindoxiti
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
#87
12-26-2019, 03:46 AM (This post was last modified: 12-26-2019, 03:47 AM by usman.)
(12-25-2019, 08:42 PM)rami1976 Wrote: Dear Admin
In the Edit Post, select Delete and press Delete Now button (if this works)
[Image: 30148820756668908934.jpg]
[-] The following 1 user Likes usman's post:1 user Likes usman's post
  â€¢ Dell_Brett
 amindoxiti
User ID: 86739
Threads: 192
Given Likes: 2618
#88
12-27-2019, 08:21 AM (This post was last modified: 12-27-2019, 08:25 AM by amindoxiti.)
Hello,
I have the same problem as he has.
  â€¢
 amindoxiti
User ID: 86739
Threads: 192
Given Likes: 2618
#89
03-13-2020, 04:33 PM
Greeting,
I don't know if these are bugs or not, but I think it's better if they exist.
1. The unread posts tag is removed.
2. Mark all as read button is removed.
3. The red unread posts mark is removed.
and one more, the delete button still does not work.
[-] The following 1 user Likes amindoxiti's post:1 user Likes amindoxiti's post
  â€¢ Dobblo
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1388
#90
08-19-2021, 09:09 PM (This post was last modified: 08-19-2021, 09:09 PM by rami1976.)
I am seeing this kind of messages so frequent
[Image: 52067225992510283179.jpg]
is it a rule or a bug?
  â€¢
Pages (10): « Previous 1 2 3 4 5 6 7 8 9 10 Next »
