Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general CIRIA Special Publication SP95 - Sheet-Piled Cofferdams
 gianniorlati
Senior Underground Works Engineer
Italy
User ID: 46169
Threads: 64
Likes: 1,673 in 128 posts
Given Likes: 429
06-04-2019, 06:27 AM (This post was last modified: 08-19-2019, 08:48 AM by lisine. Edit Reason: N/A )
The Design and Construction of sheet-piled Cofferdams
Author(s)/Editor(s): B. P. Williams - D. Waite | Size: 7.06 MB | Format: PDF | Quality: Scanner | Publisher: CIRIA - Thomas Telford | Year: 1993 | pages: 103 | ISBN: 0 86017 361 5
[Image: 41FNNS5XJ0L._SX248_BO1,204,203,200_.jpg]
This report brings together from many sources information which is likely to be needed for the successful design and construction of a cofferdam up to 10 metres deep in steel sheet piling.
It points out the need for the inclusion of the requirement for such a cofferdam in the initial project planning so that the site investigation will give the information necessary for its design.
Other sections include general planning of the cofferdam, earth and water pressure calculations, various methods of analysis for the detailed design of the wall and support system, and the construction, maintenance and removal of the cofferdam. Emphasis is given lo the considerable effect that water pressures have on the loading on the cofferdam wall, and various methods are given to establish these pressures, including the use of flow nets.
There are nurmerous checklists, comprehensive references and a bibliography, together with a number of worked examples in an appendix. While computers are used extensively in design offices, an engineer must understand the basic principles of the design, and the report helps to achieve thls understanding.
[-] The following 23 users Like gianniorlati's post:23 users Like gianniorlati's post
  â€¢ kowheng, PinkPant, blaze, ziggywas1, febo927, oanm2000, Aviator, cace-01, Nita1391, jcbv, malc, gulilero, Dell_Brett, zrilek, cristi, levanduy, Hengki, chenamoy, avge, alibouafia, Andrew seah, mgdario, vvvv
  Pile Types Selection - CIRIA Report PG1 gianniorlati 0 1,899 06-04-2019, 04:04 PM
Last Post: gianniorlati
  ciria - Piled foundations in weak rock bashir999 4 4,447 01-11-2016, 02:35 PM
Last Post: uetian19
  Full-Scale Testing and Foundation Design (Geotechnical Special Publication - GSP 227) maxpn3 0 1,946 08-11-2013, 07:35 AM
Last Post: maxpn3
