Civil Engineering Association eBooks Structural Books Steel Handbook of Steel Construction – 11th Edition, 3rd Revised Printing 2017
 carolinandra
Colombia
User ID: 12281
Threads: 112
Likes: 2,885 in 157 posts
Given Likes: 1333
04-10-2019, 12:39 PM
Author(s)/Editor(s): Canadian Institute of Steel Construction (CISC) | Size: 89.9 MB | Format: PDF | Quality: Unspecified | Publisher: Canadian Institute of Steel Construction (CISC) | Year: 2017 | pages: 1192 | ISBN: ISBN-10: 0888112033 ISBN-13: 978-0888112071
[Image: 53245829595388389134.jpg]
This comprehensive reference by the Canadian Institute of Steel Construction is the 11th Edition of the Handbook of the Steel Construction, first published in 1967. It contains detailed information on the design and detailing of structural steel in metric units. The 11th Edition has been updated to reflect changes to CSA S16-14 and the steel section data. It is intended to be used in conjunction with the National Building Code of Canada 2015. Member design tables are based on steel grades ASTM A992, A572 Grade 50, A913 Grade 65, A500 Grade C and CSA G40.21-350W. Comprising 8 parts, the contents include CSA S16-14 ("Design of Steel Structures") incorporating Update No. 1 (Dec. 2016, with a new Annex N on design and construction of steel storage racks), CISC Commentary on S16-14, Connections and Tension Members, Compression Members, Flexural Members, Properties and Dimensions, CISC Code of Standard Practice (8th Ed.) and Miscellaneous Data, and a General Index.
[-] The following 40 users Like carolinandra's post:40 users Like carolinandra's post
  • civilfafa, Aviator, febo927, vvvv, jcbv, sabooryan, amindoxiti, ersin, mgdario, PinkPant, apocalipse, frank1972, dovsky, jcoronellr, mahyarov, bridgeengineer, albani, malc, usman, Nita1391, cheosmith, kowheng, RICARDI, levanduy, blaze, pontiac, cristi, shaker, karthikeyans3d, melekeen, oanm2000, gulilero, cace-01, tuanpecc1, Dell_Brett, subin91, lasalleguy, simanta, yutt, monter
 malee
User ID: 554
Threads: 17
Likes: 1,358 in 98 posts
Given Likes: 267
04-11-2019, 01:46 AM
Mirror  Link
[-] The following 16 users Like malee's post:16 users Like malee's post
  • rfireman, noel, rami1976, levanduy, jcbv, PinkPant, pontiac, melekeen, oanm2000, emmi, cace-01, Dell_Brett, kowheng, portal61, lasalleguy, PanosP
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Likes: 4,964 in 638 posts
Given Likes: 3501
07-19-2024, 02:49 AM
concrete solution advocate
[-] The following 2 users Like concreteok's post:2 users Like concreteok's post
  • babakfeyzi, Dell_Brett
  Structural Steel Designer's Handbook 6th Edition sabooryan 2 3,027 02-04-2021, 04:31 PM
Last Post: Kurucz
  Steel Heat Treatment Handbook, Second Edition pinktt 2 2,655 12-13-2013, 01:13 PM
  THE PROCEDURE HANDBOOK OF ARC WELDING-TWELFTH EDITION malc 2 3,183 11-26-2012, 07:09 AM
Last Post: shadabg
  Handbook of Steel Drainage and Highway Construction Products ir_71 1 2,618 11-15-2012, 04:45 PM
  Metals Handbook Desk Edition Dell_Brett 2 3,111 11-09-2012, 08:55 AM
Last Post: shadabg
