Civil Engineering Association eBooks Codes, Manual & Handbook CSA CSA A23.3: Design of concrete structures
 Vladimir
Ukraine
User ID: 19969
Threads: 42
Likes: 417 in 60 posts
Given Likes: 173
01-23-2011, 07:07 AM (This post was last modified: 01-06-2012, 10:31 PM by usman.)
you can get CSA-A23.3-04 "Design of concrete Structures" here
Vladimir
[-] The following 15 users Like Vladimir's post:15 users Like Vladimir's post
  • usman, thebeatles, jcbv, Dell_Brett, jocagalhao, blaze, lamkin, malc, semenki, zero85, techno, gulilero, sivlad, kowheng, bigone
Threads: 1,298
01-06-2012, 08:51 PM (This post was last modified: 01-19-2014, 06:03 PM by oanm2000.)
CSA A23.3-04 Design of concrete structures
Size: 2.9 MB | Format: PDF | Publisher: CANADIAN STANDARDS ASSOCIATION | Year: 2004 | pages: 232 | ISBN: 1553975596
[Image: 05975015511569514521.jpg]
1 Scope
1.1 General
This Standard specifies requirements, in accordance with the National Building Code of Canada, for the design and strength evaluation of
(a) structures of reinforced and prestressed concrete;
(b) plain concrete elements; and
© special structures such as parking structures, arches, tanks, reservoirs, bins and silos, towers, water towers, blast-resistant structures, and chimneys.
Note: Special requirements for parking structures are specified in CAN/CSA-S413.
1.2 Fire resistance
This Standard requires designs to be carried out in accordance with the fire resistance requirements of the applicable building code (see Clause 8.1.2).
1.3 Alternative design procedures
Designs that use procedures which are not covered by this Standard but are carried out by a person qualified in the methods applied and provide a level of safety and performance equivalent to designs complying with this Standard are acceptable if carried out by one of the following methods:
(a) analysis based on generally established theory;
(b) evaluation of a full-scale structure or a prototype by a loading test; or
© studies of model analogues.
1.4 Terminology
In CSA Standards, “shall” is used to express a requirement, i.e., a provision that the user is obliged to satisfy in order to comply with the standard; “should” is used to express a recommendation or that which is advised but not required; “may” is used to express an option or that which is permissible within the limits of the standard; and “can” is used to express possibility or capability. Notes accompanying clauses do not include requirements or alternative requirements; the purpose of a note accompanying a clause is to separate from the text explanatory or informative material. Notes to tables and figures are considered part of the table or figure and may be written as requirements. Annexes are designated normative (mandatory) or informative (non-mandatory) to define their application.
1.5 Units of measurement
Equations appearing in this Standard are compatible with the following units:
(a) area: mm2 (square millimetres);
(b) force: N (newtons);
© length: mm (millimetres);
(d) moment: N•mm (newton millimetres); and
(e) stress: MPa (megapascals).
Whenever the square root of the concrete strength is determined, the concrete strength and the square root of the concrete strength are both expressed in megapascals. Other dimensionally consistent combinations of units may be used, provided that appropriate adjustments are made to constants in non-homogeneous equations.
Note: Some examples of non-homogeneous equations are found in Clauses 12.2.2 and 12.8.
  • techno, lasalleguy, Dell_Brett, Jackass, Milkshake, melkat, ibg0203, knrsa, seriousboy, ruaumoko, tluc, marion33, pezhmankhan, bigone, oanm2000
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
01-19-2014, 01:28 AM
Mirrors;
[-] The following 3 users Like ssobhan's post:3 users Like ssobhan's post
  • oanm2000, Dell_Brett, sherkhan
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
02-15-2014, 07:00 AM
[-] The following 11 users Like Mohammad6299's post:11 users Like Mohammad6299's post
  • ronnie_150, hatkam, Dell_Brett, SCREAM7890, cristi, sherkhan, bridgeengineer, julioreptil, harsono, simanta, lisine
 RICARDI
User ID: 6997
Threads: 47
Likes: 180 in 37 posts
Given Likes: 195
03-28-2016, 03:18 AM
CSA A23-04, Design of Concrete Structures (Canada)
  • Author(s): CSA
  • Published By: CSA
  • Published Year: 2004
  • Quality: Unspecified
  • Abstract: Design of Concrete Structures
[-] The following 20 users Like RICARDI's post:20 users Like RICARDI's post
  • psk62, blaze, cace-01, slowet, Hengki, oanm2000, melekeen, temp1366, shaker, simanta, bridgeengineer, jcbv, Dell_Brett, anfaga, knrsa, peixoto, malc, araza023, Jackass, SCREAM7890
Likes: 12,075 in 1,233 posts
02-28-2017, 03:04 AM (This post was last modified: 02-28-2017, 08:41 PM by faros3000. Edit Reason: Publisher info editing. )
CSA A23.3-14, Design of concrete structures
Size: 4.5 MB | Format: PDF | Quality: Original preprint | Publisher: Canadian Standards Association operating as CSA Group | Year: 2014 | pages: 295
[Image: 53333908573803741388.jpg]
This is the sixth edition of CSA A23.3, Design of concrete structures. It supersedes the previous editions published in 2004, 1994, 1984, 1977 (metric), and 1973 (imperial), and 1959.
This Standard is intended for use in the design of concrete structures for buildings in conjunction with CSA A23.1/A23.2, Concrete materials and methods of concrete construction/Methods of test and standard practices for concrete, and CSA A23.4, Precast concrete - Materials and construction.
[-] The following 26 users Like pezhmankhan's post:26 users Like pezhmankhan's post
  • KhaLed-S.E, concreteok, malc, Hengki, rami1976, blaze, herea, civilfafa, RyanRS, amindoxiti, lasalleguy, Aviator, Dell_Brett, shaker, simanta, temp1366, usman, noel, monter, bigone, cheosmith, miquan, visu, jaks, Batman07, PanosP
10-06-2021, 11:43 AM
CSA A23.3:19, Design of concrete structures
| Size: 3 MB| Format: PDF| Quality: Original preprint| Publisher: National Standard of Canada| Year: 2019| pages: 301 | ISBN: 978-1-4883-2168-9
[Image: 18011268959919294981.jpg]
[-] The following 14 users Like pezhmankhan's post:14 users Like pezhmankhan's post
  • Aviator, poolmand, blaze, caifan, cheosmith, gulilero, usman, concreteok, vvvv, Dell_Brett, kowheng, zrilek, oanm2000, BeOnlyOne
 sandeepb
User ID: 33504
Threads: 16
Likes: 217 in 32 posts
Given Likes: 9
10-07-2021, 06:50 PM
The above link is working. Another location:
[-] The following 11 users Like sandeepb's post:11 users Like sandeepb's post
  • vampirucho, rami1976, concreteok, PinkPant, malc, Dell_Brett, Administrator , kowheng, cace-01, zrilek, oanm2000
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
10-09-2021, 05:53 AM (This post was last modified: 05-05-2024, 11:22 AM by Administrator.)
[-] The following 10 users Like poolmand's post:10 users Like poolmand's post
  • Administrator , jcbv, kowheng, cace-01, zrilek, Dell_Brett, PinkPant, oanm2000, gulilero, lisine
Threads: 750
Given Likes: 88
#10
07-21-2024, 09:18 AM
CSA A23.3:24 Design of concrete structures
| Size: 17.8 MB| Format: PDF| Quality: Original preprint| Publisher: CSA Group| Year: 2024| pages: 341
  • babakfeyzi, PinkPant, Dell_Brett
