Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 6349-1: Maritime Structures: Code of Practice for General Criteria
 Gabemzaman
User ID: 2838
Threads: 19
Likes: 1,073 in 79 posts
Given Likes: 379
11-12-2009, 03:53 PM (This post was last modified: 09-13-2012, 10:38 AM by lisine.)
BS 6349 1-7 : Maritime structures
BS 6349-1:2000 - Maritime structures. Code of practice for general criteria
BS 6349-2:1988 - Maritime structures. Design of quay walls, jetties and dolphins
BS 6349-3:1988 - Maritime structures. Design of dry docks, locks, slipways and shipbuilding berths, shiplifts and dock and lock gates
BS 6349-5:1991 - Maritime structures. Code of practice for dredging and land reclamation
BS 6349-6:1989 - Maritime structures. Design of inshore moorings and floating structures
BS 6349-7:1991 - Maritime structures. Guide to the design and construction of breakwaters
Download Links:
[-] The following 14 users Like Gabemzaman's post:14 users Like Gabemzaman's post
  â€¢ paulocs, vvvv, kowheng, donaldk, Dell_Brett, arturom, chenamoy, zrilek, jacs127, julioreptil, hadeest, sackk, wanwin, nhim4mat2006
11-19-2010, 01:47 PM
BS 6349 Maritime structures
Size: 16 MB | Format: PDF | Publisher: BSI | Year: 1988-2007
BS 6349-1:2000 Maritime structures. Code of practice for general criteria
This part of BS 6349 gives guidance and recommendations on general criteria relevant to the planning, design, construction and maintenance of structures set in the maritime environment.
This British Standard is arranged on a topical basis. Section 2 discusses environmental factors, in which the environment is taken in its broader sense to include all naturally occurring phenomena likely to be found at a coastal site and guidance is given on methods of investigating and quantifying their effects. Section 3 gives prominence to the need to consider operational requirements throughout the planning of maritime works, although only limited guidance is given on some general aspects because the detailed functional requirements of individual structures are beyond the scope of this part of this code. Section 4 discusses sea state and gives guidance on the characteristics, prediction, recording and effect of waves. Section 5 deals with the selection and evaluation of design loadings arising from the environmental and operational effects discussed in the previous sections, taking due account of dynamic response and fatigue. Section 6 discusses geotechnical aspects, including ground investigations, soil parameters, and geotechnical design requirements. Section 7 gives guidance on the use and specification of appropriate materials and protective measures.
This Part of BS 6349 also gives recommendations to assist clients and engineers to obtain the basic data relevant to the design of any maritime structure.
BS 6349-2:1988 Maritime works. Code of practice for the design of quay walls,jetties and dolphins
BS 6349-2 provides recommendations and guidance on the design of quay walls, jetties and dolphins.
This is a full revision of BS 6349-2 and introduces the following principal changes:
Substantial reference to Eurocodes and other European standards published since the previous edition of BS 6349-2
Some rationalization arising from the publication of BS 6349-8, which now deals with all issues associated with Ro-Ro ramps, linkspans and walkways
Change of title from Maritime structures to Maritime works to reflect the expanded remit of the new Technical Committee that is responsible for this series. The titles of the other parts will be changed as revisions or amendments are published.
BS 6349-2:2010 replaces BS 6349-2:1988, which is now withdrawn.
BS 6349-3:1988 Maritime structures. Design of dry docks, locks, slipways and shipbuilding berths, shiplifts and dock and lock gates
BS 6349-4:1994 Maritime structures. Code of practice for design of fendering and mooring systems
BS 6349-5:1991 Maritime structures. Code of practice for dredging and land reclamation
BS 6349-6:1989 Maritime structures. Design of inshore moorings and floating structures
BS 6349-7:1991 Maritime structures. Guide to the design and construction of breakwaters
BS 6349-8:2007 Maritime structures. Code of practice for the design of Ro-Ro ramps, linkspans and walkways
This part of BS 6349 gives recommendations for the design of roll-on/roll-off (Ro-Ro) ramps, linkspans and walkways, used for the transfer of passengers and vehicles between shore and ship.
It applies to the structural elements only and does not cover the design of any operational equipment, traffic control, mechanical or electrical equipment, heating, lighting, life saving or rescue equipment other than as the structures forming a facility need to incorporate and/or support any of these features. Most geometrical aspects of fixed shore ramps are covered in this part of BS 6349, but recommendations for all other aspects are given in BS 6349-2.
This part of BS 6349 does not apply to Ro-Ro facilities used by rail vehicles in that it does not give recommendations for railway loading and associated ramp gradients. However, many of its recommendations are applicable to rail Ro-Ro facilities and can be used in the absence of other guidance.
NOTE This part of BS 6349 is generally intended to cover facilities constructed in the British Isles. Although the majority of the contents are directly applicable elsewhere, local conditions might necessitate modifications, e.g. environmental effects and traffic loading.
  â€¢ Administrator , Dell_Brett, kg85arun, Grunf, ssi3k, snakes, kowheng, super_engineer, axee1980, toa011, civilteam, Adam Smith, zrilek, roaming79, dbsimon29, duazo2009, oanm2000, malc, concorida2, monter, Limpias72, mladenpr, delhite, nhim4mat2006
 jacs127
Senior Member
User ID: 11255
Threads: 93
Likes: 1,667 in 225 posts
Given Likes: 605
03-04-2011, 10:38 AM
BS 6349-2:2009 Maritime works. Code of practice for the design of quay walls,jetties and dolphins...The updated and recent one. though it is not final but the final version is not much changed than this.
[-] The following 11 users Like jacs127's post:11 users Like jacs127's post
  â€¢ kowheng, blaze, zrilek, Adam Smith, oanm2000, ir_71, concorida2, Limpias72, mladenpr, delhite, Dell_Brett
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
09-13-2012, 10:36 AM
BS 6349 Maritime structures - Part 1-8
Author: Technical Committee CB/502, Maritime works | Size: 18.1 MB | Format: PDF | Quality: Original preprint | Publisher: BSI | Year: - | pages: - | ISBN: -
BS 6349-1:2000
BS 6349-2:2010
Maritime works. Code of practice for the design of quay walls, jetties and dolphins
BS 6349-3:1988
BS 6349-4:1994
BS 6349-5:1991
BS 6349-6:1989
BS 6349-7:1991
BS 6349-8:2007
Note:
All current version (sept. 2012)
[-] The following 18 users Like lisine's post:18 users Like lisine's post
  â€¢ shadabg, duazo2009, seriousboy, zrilek, blaze, cace-01, mahyarov, malc, kowheng, Andrew seah, st77bel, Jackass, ashcivilea, peixoto, Dell_Brett, dinu69in, Evandrojr, jocagalhao
01-23-2017, 05:44 PM
BS 6349 Maritime structures - Part 1-8 Updated
  â€¢ civilfafa, Dell_Brett, malc, zrilek, oanm2000, Hengki, peixoto, blaze
06-29-2017, 07:10 PM
  â€¢ Nita1391, Dell_Brett, zrilek, PinkPant, Aviator, oanm2000
 cod-X
User ID: 45
Threads: 31
Likes: 504 in 63 posts
Given Likes: 269
02-15-2018, 10:49 AM
sorry to post here as request but its related to this standard and I dont want to have many topics.
does anyone can find BS 6349-1-2:2016+A1:2017?
>> First learn from cracked software than be licensed1 <<
  â€¢
 lisine
Vanuatu
User ID: 17927
Threads: 265
Given Likes: 4631
11-23-2018, 01:43 PM
Files inside archive:
BS 06349-1-1-2013.pdf
BS 06349-1-3-2012.pdf
BS 06349-1-4-2013.pdf
BS 06349-2-2010.pdf
BS 06349-3-2013.pdf
BS 06349-4-2014.pdf
BS 06349-5-1991 (1999).pdf
BS 06349-6-1989 (1999).pdf
BS 06349-7-1991 (2010).pdf
BS 06349-8-2007.pdf
BS 6349-1-2000.pdf
BS 6349-2-1988.pdf
BS 6349-2-2010.pdf
BS 6349-3-1988.pdf
BS 6349-4-1994.pdf
BS 6349-5-1991.pdf
BS 6349-6-1989.pdf
BS 6349-7-1991.pdf
BS 6349-8-2007.pdf
[-] The following 10 users Like lisine's post:10 users Like lisine's post
  â€¢ zrilek, chukwuma, PinkPant, cace-01, oanm2000, Umer.Aleem, Dell_Brett, jcbv, Wijono, er.shyams
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
09-04-2021, 08:47 AM
BS 6349-1: 2021 Maritime Structures: Code of Practice for General Criteria
| Size: 2 MB| Format: PDF| Quality: Original preprint| Publisher: BSI Group| Year: 2021| pages: 88 | ISBN: 9780539122251
[Image: 52406859698540039692.jpg]
This part of BS 6349 gives recommendations for the materials used in the design and construction of maritime environment structures, and includes specific provisions for use in a seawater environment.
[-] The following 15 users Like poolmand's post:15 users Like poolmand's post
  â€¢ zrilek, blaze, malc, Administrator , babakfeyzi, jcbv, PinkPant, kowheng, Dell_Brett, pedzaquino, Aviator, mohamz, oanm2000, nhim4mat2006, Umer.Aleem
 ersin
User ID: 980
Threads: 10
Likes: 57 in 19 posts
Given Likes: 208
#10
06-07-2023, 05:10 AM
Can you share new download link?
[-] The following 1 user Likes ersin's post:1 user Likes ersin's post
  â€¢ Umer.Aleem
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,200 05-29-2024, 12:10 PM
  BS EN 1992-1-1: Eurocode 2. Design of concrete structures. General rules and rules f poolmand 0 3,114 01-14-2024, 10:00 AM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,913 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,412 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,697 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,271 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,541 02-17-2021, 11:20 AM
Last Post: temp1366
