Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC 358: Prequalified Connections for Special and Intermediate Steel Moment Frames
 Ultra Zone
Senior Member
El Salvador
User ID: 195
Threads: 102
Likes: 2,410 in 167 posts
Given Likes: 2238
08-14-2009, 03:42 PM (This post was last modified: 01-12-2022, 11:22 AM by Administrator.)
Supplement No. 1 to ANSI/AISC 358-05
August 4, 2009 from American Institute of Steel Construction
(Chicago, IL) – A valuable resource that provides a greater variety of prequalified moment connections options for special moment frames (SMF) and intermediate moment frames (IMF) is now available for designers of steel structures in high seismic regions.
ANSI/AISC 358-05s1 is a supplement to the 2005 AISC standard, Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications. The document modifies an existing prequalified moment connection and adds three new prequalified moment connections.
When it was first introduced in 2005, AISC Prequalified Connections covered three connection types: reduced beam section (RBS) moment connections, bolted unstiffened extended end-plate (BUEEP) moment connections, and bolted stiffened extended end-plate (BSEEP) moment connections. A limitation was necessary at that time on both of the prequalified extended end-plate moment connections: they could not be used with composite concrete structural slabs in SMF.
Supplement No. 1 to ANSI/AISC 358-05 provides three more prequalified connection types and eliminates the prohibition of composite slabs for extended end-plate moment connections in SMF. Supplement No. 1 also adds prequalified details for bolted flange plate (BFP) moment connections, welded unreinforced flange - welded web (WUF-W) moment connections, and Kaiser bolted bracket (KBB) moment connections.
ANSI/AISC 358-05s1 is available for free download along with ANSI/AISC 358-05, ANSI/AISC341-05, and ANSI/AISC 360-05 at:
Follow the Rules
[-] The following 17 users Like Ultra Zone's post:17 users Like Ultra Zone's post
  • Panjack39, Panjack39, Dell_Brett, Dell_Brett, kowheng, kowheng, rohailiyaz, rohailiyaz, oanm2000, oanm2000, vvvv, vvvv, robox514, robox514, carolinandra, lesgiu, Hengki
Threads: 1,298
03-16-2011, 10:18 AM
ANSI/AISC 358-05 Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications
Author: AISC | Size: 1.2 MB | Format: PDF | Publisher: ANSI/AISC | Year: 2006 | pages: 90
[Image: 52896382109403226735.jpg]
This Standard specifies design, detailing, fabrication and quality criteria for connections that are prequalified in accordance with the AISC Seismic Provisions for Structural Steel Buildings (herein referred to as the AISC Seismic Provisions) for use with special moment frames (SMF) and intermediate moment frames (IMF). The connections contained in this Standard are prequalified to meet the requirements in the AISC Seismic Provisions only when designed and constructed in accordance with the requirements of this Standard. Nothing in this Standard shall preclude the use of connection types contained herein outside the indicated limitations, or the use of other connection types, when satisfactory evidence of qualification in accordance with Appendix S of the AISC Seismic Provisions is presented to the authority having jurisdiction.
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  • blaze, Dell_Brett, toa011, cordoba123, seriousboy, yantonegr, jcoronellr, usman, Clouseau, malc, robertsas, goober, ASEC, monter, jcbv, fer962933, YeiYei, sivlad, Jackass, julioreptil, oanm2000
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 282
Likes: 21,192 in 2,352 posts
Given Likes: 4260
11-16-2011, 06:34 AM
ANSI/AISC 358-10 and 358s1-11
(Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications)
Size: 2.22 MB | Format: PDF | Publisher: AISC | Year: 2010, 2011 | pages: 178
[Image: 73247622995829027819.png]
(Chicago) – The 2010 AISC standard Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications (AISC 358-10) is now available for public review. This document is a consolidation of the existing Prequalified Connections standard (ANSI/AISC 358-05) and its supplement (ANSI/AISC 358-05s1-09). The consolidated standard includes all five prequalified moment connections, as well as revisions for consistency with the upcoming 2010 AISC Seismic Provisions for Structural Steel Buildings (AISC 341-10).
The draft standard is available for your review by downloading the document at the links provided below. A paper copy of the standard can also be requested for a fee of $15 by contacting Janet Cummins at 312-670-5411 or by e-mailing [email protected].
You may submit comments using the online comment form available at aisc.org/AISC358prcomment.
Alternatively, you may e-mail your comments, with your name and complete contact information, to [email protected].
Made By CivilEA Post-Generator ver 2.1[url=http://forum.civilea.com/postgen/icon/index.html][/url]
[-] The following 14 users Like Administrator 's post:14 users Like Administrator 's post
  • kowheng, miquan, Jackass, atram, Dell_Brett, yeka, oanm2000, malc, toa011, nowanda, XXXX123, bigone, pezhmankhan, arshiakh
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
11-16-2011, 06:51 AM
Mirror:
[-] The following 18 users Like miquan's post:18 users Like miquan's post
  • pedzaquino, Dell_Brett, yeka, oanm2000, malc, subin91, XXXX123, bigone, mr.nicus, Jarty, carolinandra, zrilek, blaze, ting tsai huang, Rapaig, amindoxiti, arshiakh, spat
 malc
User ID: 30599
Threads: 66
Likes: 1,520 in 155 posts
Given Likes: 15191
05-05-2014, 06:34 PM
ANSI/AISC 358-10 Prequalified Connections Special Steel Moment Frames
Author: AISC | Size: 2.53 MB | Format: PDF | Quality: Original preprint | Publisher: AISC | Year: 2014 | pages: 222 | ISBN: -
[Image: 77013002620474395981.jpg]
This standard design detailing specifies fabrication and quality criteria for connections that are prequalified according to AISC Seismic Provisions for Structural Steel Buildings.
SUPPLEMENT No 1 2011
SUPPLEMENT No 2 2014
[Image: comments.png]
Best Regards to All
[-] The following 19 users Like malc's post:19 users Like malc's post
  • zrilek, pezhmankhan, shaker, vardan, oanm2000, Diquan, Mohammad6299, bigone, subin91, blaze, ykhackhack, knrsa, Dell_Brett, dinu69in, mgdario, nickycruz, Rapaig, amindoxiti, arshiakh
 sinamaleki
User ID: 20260
Threads: 1
Likes: 154 in 14 posts
Given Likes: 28
11-29-2014, 10:31 PM
Direct Link
only supplement No.1
[-] The following 8 users Like sinamaleki's post:8 users Like sinamaleki's post
  • amindoxiti, oanm2000, bigone, bridgeengineer, ssobhan, Dell_Brett, vvvv, arshiakh
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
12-01-2014, 08:26 AM
This is free publication from AISC
you can find it from link below
[-] The following 8 users Like mybest's post:8 users Like mybest's post
  • vvvv, Dell_Brett, agelos100, PinkPant, oanm2000, Mohammad6299, bigone, amindoxiti
 ESTRUCTO
User ID: 2666
Likes: 183 in 21 posts
Given Likes: 35
11-10-2016, 04:39 PM (This post was last modified: 01-12-2022, 11:16 AM by Administrator.)
AISC 358-16 Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications
Author(s)/Editor(s): AISC | Size: 7855 KB | Format: PDF | Quality: Unspecified | Publisher: AISC | Year: 2016 | pages: 284
[Image: 67374482176887897152.jpg]
AISC 358-16 "Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications."
ANSI/AISC 358-16, Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications, was developed using a consensus process in concert with the Specification for Structural Steel Buildings (ANSI/AISC 360-16) and Seismic Provisions for Structural Steel Buildings (ANSI/AISC 341-16). ANSI/AISC 358-16 is incorporated by reference into the Seismic Provisions.
This edition includes minor editorial updates and clarifications from previous versions as well as two additional prequalified moment connections: the Simpson Strong Frame moment connection (Chapter 12) and the double-tee moment connection (Chapter 13).
A nonmandatory Commentary has been prepared to provide background for the provi-sions of the Standard, and the user is encouraged to consult it. Additionally, nonmandatory User Notes are interspersed throughout the Standard to provide concise and practical guid-ance in the application of the provisions.
[-] The following 12 users Like ESTRUCTO's post:12 users Like ESTRUCTO's post
  • struc_engg, zrilek, pezhmankhan, oanm2000, karthikeyans3d, Jackass, K.Lee, jcbv, Dell_Brett, araza023, vvvv, tuanpecc1
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
11-10-2016, 10:23 PM (This post was last modified: 10-21-2018, 06:39 AM by Administrator.)
DIRECT LINK FROM SOURCE
[-] The following 9 users Like gulilero's post:9 users Like gulilero's post
  • Dell_Brett, blaze, PinkPant, slowet, oanm2000, pram, malc, araza023, bigone
 AtoZmail
United States
User ID: 91376
Threads: 2
Likes: 78 in 5 posts
Given Likes: 0
#10
04-27-2017, 02:07 PM
UPDATED DIRECT LINK FROM SOURCE
[-] The following 21 users Like AtoZmail's post:21 users Like AtoZmail's post
  • amindoxiti, hatkam, Nita1391, zrilek, PinkPant, jcbv, Dell_Brett, caifan, milova, cheosmith, agelos100, subin91, jcoronellr, oanm2000, blackjack, promo8, xdesi, bigone, febo927, sacem, levanduy
Pages (2): 1 2 Next »
  AISC - Steel Design Guides Administrator 75 84,900 06-13-2026, 09:38 AM
  AISC - Steel Construction Manual dinu69in 26 26,651 06-10-2026, 12:17 PM
  ANSI/AISC N690: Specification for Safety-Related Steel Structures for Nuclear Facil ir_71 5 12,831 08-18-2025, 07:07 AM
  AISC Model Review and Approval for Structural Steel poolmand 0 3,579 04-29-2024, 07:29 AM
  AISC BIM & VDC FOR STRUCTURAL STEEL poolmand 0 3,163 04-29-2024, 07:27 AM
  AISC Conference: Composite Construction in Steel and Concrete VIII poolmand 0 2,976 12-04-2023, 09:17 AM
  AISC: Facts for Steel Buildings tarugo 8 8,687 12-04-2023, 09:11 AM
