11-11-2014, 07:04 AM
LavT License generator for ETABS 2013 13.2.0
attached
attached
The following 38 users Like bigone's post:β’ amindoxiti, jokerβ’,
11-21-2014, 07:40 PM
ETABS 13.2.1 installation (use the same license generator as previous version)
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
The following 38 users Like BennyP's post:β’ ebzr, Williams, red_pool61, zrilek, dl4all, MOSS2000, rezart, oanm2000, aslam, raja, simanta, pezhmankhan, kirankumarklk,
12-04-2014, 01:14 AM
(This post was last modified: 12-04-2014, 01:34 AM by Dell_Brett.)
ETABS 2013 v13.2.0 Size: 354.34 MB
Computers and Structures, Inc. (CSI), leader in software tools for structural and earthquake engineering, has released an update to CSI ETABS 13, is a civil engineering program that design and analyse steel and concrete structures using finite element method. ETABS 2013 provides an unequaled suite of tools for structural engineers designing buildings, whether they are working on one-story industrial structures or the tallest commercial high-rises. Immensely capable, yet easy-to-use, has been the hallmark of ETABS since its introduction decades ago, and this latest release continues that tradition by providing engineers with the technologically-advanced, yet intuitive, software they require to be their most productive. Significant enhancements included in ETABS 2013 version 13.2.0: - The Auto-Relabel All option that was available in ETABS v9 has been restored. - Russian material property and section property libraries have been added. - ASCE 41-13 guidelines for performance-based design have been implemented for frame hinge definitions, performance-point calculations, and the behavior and acceptance criteria for panel-zones and BRBs (buckling-restrained braces). - Masonry is now defined as a separate material rather than a type of concrete material. - Multiple named mass-source definitions can now be created and used for different load cases. - The Singapore National Annex has been added as an option to the Euroquote 8-2004 response spectrum function. - Notional load patterns can now be based on snow loads as well as other gravity loads. - User control is now provided for the handling of self-weight in the end offset portions of beam members. - The speed of analysis has been increased for most load cases. - The iteration strategy for nonlinear static and nonlinear direct-integration time-history load cases has been made more adaptive to typically improve convergence behavior and to reduce the time of analysis. - The line-search algorithm is now available for nonlinear static analysis. - Steel frame design for the Indian IS 800:2007 quote now implements the changes in Amendment Number 1. - The display of design input parameters for steel frame design overwrites has been enhanced. - Canadian design quotes (i.e., CSA A23.3-04 and CSA S16-09) now include snow loads in the default design combinations. - Multiple enhancements have been made for composite beam design affecting the control of the design process, the look and functionality of the interactive design form, the format and content of the output, and other improvements. - Shear wall design per the Indian IS 456:2000 quote now allows separate control in the major and minor directions for enforcing the minimum eccentricity due to slenderness. - Several database tables have been added or have had their content expanded, including the listing of object unique names where applicable. - Table set definitions are now saved in the text model file. Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
12-05-2014, 11:00 AM
CSI ETABS 2013 13.2.1 November 2014| 733 MB Size: 733 MB
![]() Computers and Structures, Inc. (CSI), leader in software tools for structural and earthquake engineering, has released an update to CSI ETABS 13, is a civil engineering program that design and analyse steel and concrete structures using finite element method. ETABS 2013 provides an unequaled suite of tools for structural engineers designing buildings, whether they are working on one-story industrial structures or the tallest commercial high-rises. Immensely capable, yet easy-to-use, has been the hallmark of ETABS since its introduction decades ago, and this latest release continues that tradition by providing engineers with the technologically-advanced, yet intuitive, software they require to be their most productive. ETABS 2013 13.2.1 Enhancements Significant enhancements included in ETABS 2013 version 13.2.0 and version 13.2.1: - The Auto-Relabel All option that was available in ETABS v9 has been restored. - Russian material property and section property libraries have been added. - ASCE 41-13 guidelines for performance-based design have been implemented for frame hinge definitions, performance-point calculations, and the behavior and acceptance criteria for panel-zones and BRBs (buckling-restrained braces). - Masonry is now defined as a separate material rather than a type of concrete material. - Multiple named mass-source definitions can now be created and used for different load cases. - The Singapore National Annex has been added as an option to the Eurocode 8-2004 response spectrum function. - Notional load patterns can now be based on snow loads as well as other gravity loads. - User control is now provided for the handling of self-weight in the end offset portions of beam members. - The speed of analysis has been increased for most load cases. - The iteration strategy for nonlinear static and nonlinear direct-integration time-history load cases has been made more adaptive to typically improve convergence behavior and to reduce the time of analysis. - The line-search algorithm is now available for nonlinear static analysis. - Steel frame design for the Indian IS 800:2007 code now implements the changes in Amendment Number 1. - The display of design input parameters for steel frame design overwrites has been enhanced. - Canadian design codes (i.e., CSA A23.3-04 and CSA S16-09) now include snow loads in the default design combinations. - Multiple enhancements have been made for composite beam design affecting the control of the design process, the look and functionality of the interactive design form, the format and content of the output, and other improvements. - Shear wall design per the Indian IS 456:2000 code now allows separate control in the major and minor directions for enforcing the minimum eccentricity due to slenderness. - Several database tables have been added or have had their content expanded, including the listing of object unique names where applicable. - Table set definitions are now saved in the text model file. About Computers and Structures, Inc Founded in 1975, Computers and Structures, Inc. (CSI) is recognized globally as the pioneering leader in software tools for structural and earthquake engineering. Software from CSI is used by thousands of engineering firms in over 160 countries for the design of major projects, including the Taipei 101 Tower in Taiwan, One World Trade Center in New York, the 2008 Olympics Birds Nest Stadium in Beijing and the cable-stayed Centenario Bridge over the Panama Canal. CSI's software is backed by more than three decades of research and development, making it the trusted choice of sophisticated design professionals everywhere! Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
The following 14 users Like TAFATNEB's post:β’ oanm2000, MOSS2000, PinkPant, CSI ETABS 13.2.1 Size: 733 MB
Mirror of post # 29 Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
12-24-2014, 04:13 AM
ETABS 2013 v13.2.2
12-30-2014, 05:35 AM
Don't forget. You can use Date Fake and this is the maximum you can reach.
The following 13 users Like BennyP's post:β’ malc, zrilek, thanzawtun, Dell_Brett,
Med only for v13.2.2. Not tested.
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π All credits go to LAV Team. Password as usual.
12-30-2014, 02:10 PM
(This post was last modified: 12-30-2014, 02:43 PM by Dell_Brett.)
Note:
- The medicine of the post above is the same as posted previously!
01-09-2015, 03:42 PM
CSI ETABS 2013 version 13.2.2 Size: 740 MB
![]() Significant enhancements included in ETABS 2013 v13.2.0, v13.2.1, and v13.2.2: - The Auto-Relabel All option that was available in ETABS v9 has been restored. - Russian material property and section property libraries have been added. - ASCE 41-13 guidelines for performance-based design have been implemented for frame hinge definitions, performance-point calculations, and the behavior and acceptance criteria for panel-zones and BRBs (buckling-restrained braces). - Masonry is now defined as a separate material rather than a type of concrete material. - Multiple named mass-source definitions can now be created and used for different load cases. - The Singapore National Annex has been added as an option to the Eurocode 8-2004 response spectrum function. - Notional load patterns can now be based on snow loads as well as other gravity loads. - User control is now provided for the handling of self-weight in the end offset portions of beam members. - The speed of analysis has been increased for most load cases. - The iteration strategy for nonlinear static and nonlinear direct-integration time-history load cases has been made more adaptive to typically improve convergence behavior and to reduce the time of analysis. - The line-search algorithm is now available for nonlinear static analysis. - Steel frame design for the Indian IS 800:2007 code now implements the changes in Amendment Number 1. - The display of design input parameters for steel frame design overwrites has been enhanced. - Canadian design codes (i.e., CSA A23.3-04 and CSA S16-09) now include snow loads in the default design combinations. - Multiple enhancements have been made for composite beam design affecting the control of the design process, the look and functionality of the interactive design form, the format and content of the output, and other improvements. - Shear wall design per the Indian IS 456:2000 code now allows separate control in the major and minor directions for enforcing the minimum eccentricity due to slenderness. - Several database tables have been added or have had their content expanded, including the listing of object unique names where applicable. - Table set definitions are now saved in the text model file. About Computers and Structures, Inc Founded in 1975, Computers and Structures, Inc. (CSI) is recognized globally as the pioneering leader in software tools for structural and earthquake engineering. Software from CSI is used by thousands of engineering firms in over 160 countries for the design of major projects, including the Taipei 101 Tower in Taiwan, One World Trade Center in New York, the 2008 Olympics Birds Nest Stadium in Beijing and the cable-stayed Centenario Bridge over the Panama Canal. CSI's software is backed by more than three decades of research and development, making it the trusted choice of sophisticated design professionals everywhere! Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π |
