Civil Engineering Association eBooks Journals, Papers and Presentations Buckling of built-up compression members in the plane of the connectors
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
04-05-2013, 03:33 AM (This post was last modified: 12-14-2014, 01:23 AM by oanm2000.)
Author: MURRAYC. TEMPLEA ND GHADAE LMAHDY | Size: 690 KB | Format: PDF | Quality: Unspecified | Publisher: Canadian Journal of Civil Engineering | Year: 1993 | pages: 16
An examination of the requirements for the design of built-up compression members in the North American and European standards and specifications reveals a great variation in the allowable maximum slenderness ratio for an individual main member, and also in the determination of an equivalent slenderness ratio. The requirements of the Canadian standard with regard to the determination of the maximum allowable slenderness ratio of a main member between points of connection can be a bit confusing.
This research involved a study of model built-up members that buckled about an axis perpendicular to the plane of the connectors. Twenty-four tests were conducted on model built-up members. The theoretical analysis consisted of a finite element analysis of the model built-up struts. In addition, an equivalent slenderness ratio was calculated by several methods. These equivalent slenderness ratios were then used in conjunction with the requirements of the Canadian standard to calculate a compressive resistance, which was compared with the experimental failure load.
From this research on built-up members that buckle about an axis perpendicular to the plane of the connectors it was found that at least two connectors should be used, that the slenderness ratio of the main member between points of connection has a significant effect on the compressive resistance, and that Timoshenko's equivalent slenderness ratio when used in conjunction with the Canadian standard gives results that are in the best agreement with the experimental results.
  β€’ Dell_Brett, malc, lisine, slowet, kowheng, tluc, ssobhan, ykhackhack
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
12-12-2014, 04:26 PM
[-] The following 10 users Like Mohammad6299's post:10 users Like Mohammad6299's post
  β€’ amindoxiti, Jackass, PinkPant, zrilek, Dell_Brett, dinu69in, subin91, oanm2000, ykhackhack, milova
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
12-12-2014, 04:39 PM
[-] The following 5 users Like Veggeta's post:5 users Like Veggeta's post
  β€’ PinkPant, jcbv, knrsa, oanm2000, ykhackhack
  BEHAVIOUR OF STEEL SINGLE ANGLE COMPRESSION MEMBERS AXIALLY LOADED THROUGH ONE LEG asim99 1 5,352 10-15-2014, 11:00 PM
Last Post: KhaLed-S.E
  Design of Cold Formed Steel Unequel Angle Compression Members darkdkay 2 7,183 10-15-2014, 10:51 PM
  Capacity interaction in brick masonry under simultaneous in-plane and out-of-plane lo arshiakh 0 3,881 04-24-2013, 07:10 PM
Last Post: arshiakh
  Slenderness ratio of main members between interconnectors of built-up compression mem asim99 0 3,952 04-05-2013, 03:40 AM
  Equivalent slenderness ratio for built-up members asim99 0 4,172 04-05-2013, 03:36 AM
  Cyclic Out‐of‐Plane Buckling of Double‐Angle Bracing asim99 0 3,927 04-03-2013, 04:44 PM
  Design Rules of Built‐Up Members in Load and Resistance Factor Design asim99 0 4,165 04-03-2013, 04:22 PM
