Civil Engineering Association eBooks Structural Books Concrete PCA: Strength Design of Anchorage to Concrete
 oscargon
Nicaragua
User ID: 26134
Threads: 10
Likes: 396 in 26 posts
Given Likes: 212
11-04-2012, 04:42 AM (This post was last modified: 11-06-2012, 06:33 PM by oanm2000.)
Author: Ronald A. Cook | Size: 1.69 MB | Format: PDF | Quality: Original preprint | Publisher: Portland Cement Association | Year: 1999 | pages: 86 | ISBN: 0-89312-2025
[Image: 58293598164164447794.jpg]
During the ACI 318-89 and ACI 318-95 code seminars, engineers and architects asked repeatedly about when the ACI 318 Building Code would include design provisions for anchorage to concrete. For the last several years, ACI Committees 318 (Standard Building Code), 349 (Concrete Nuclear Sructures), and 355 (Anchorage to Concrete) have worked diligently on developing such provisions. As discussed in the Introduction of this publication, Committee 318 came very close to completing an Appendix D to ACI 318-99, with code provisions and commentary, for strength design of anchorage to concrete. ACI 318 Appendix D continues to be processed under the ACI consensus process. The code provisions and commentary of the proposed ACI 318 Appendix D for cast-in-Place anchors only are reproduced in Appendices A and B of this document, respectively. The contents of Appendices A and B are copyrighted material and reproduced with permission from the American Concrete Institute (ACI). These two appendices are not an official ACI document, but rather part of a document being processed as an ACI consensus standard. The document, as well as the final consensus standard, will be the copyright of ACI. With permission from ACI, the design provisions of Appendix A of this publication are incorporated, with limited amendments, into the first edition of the International Building Code (IBC 2000) as Section 1913.
The primary purpose for publishing this document is to assist the engineer and architect in the implementation of the design provisions for anchorage to concrete. Six design examples illustrate the application of the design provisions for single and group anchors; subject to tension, shear, or combined tension and shear; with or without eccentricity; and with or without edge effects.
[-] The following 47 users Like oscargon's post:47 users Like oscargon's post
  • Hengki, david-smith, malc, usman, vardan, techno, Albert, Dell_Brett, kowheng, ykhackhack, blaze, thebeatles, 88FeNIX, Clouseau, cace-01, warlord1, miquan, seriousboy, agelos100, ruaumoko, lednar_ved, knrsa, cardinal85, Diquan, sodapas, gulilero, mgdario, Jackass, vvvv, ibg0203, StaadEng, chrono146, subin91, shadabg, jayborre, lisine, chenamoy, araza023, bigone, psk62, nibbi, jacs127, dinu69in, jacs1976, julioreptil, jcbv, promo8
 r3be1
San Marino
User ID: 424
Threads: 47
Likes: 2,809 in 355 posts
Given Likes: 101
08-29-2014, 02:39 PM
password (1st link)
[-] The following 16 users Like r3be1's post:16 users Like r3be1's post
  • zrilek, Mohammad6299, cace-01, chrono146, slowet, malc, milova, cristi, PinkPant, Trishu999, eliseo.as, Diquan, Dell_Brett, bridgeengineer, simanta, ruaumoko
  CS TR49: Design Guidance for High Strength Concrete ir_71 2 3,103 05-06-2016, 12:01 PM
Last Post: scorpion07
  High-Strength Concrete: A Practical Guide ribak 11 7,569 02-12-2016, 04:39 PM
  Anchorage in Concrete Construction hich 5 4,551 09-19-2015, 03:15 PM
Last Post: ibg0203
  Design of High Strength Concrete Members (Mendis) durden 1 2,472 06-12-2014, 11:49 AM
Last Post: subin91
  Flexural Anchorage Performance at Diagonal Crack Locations mahyarov 0 1,478 11-07-2012, 02:38 PM
Last Post: mahyarov
  External Post-Tensioning Anchorage mahyarov 0 1,529 11-07-2012, 02:33 PM
Last Post: mahyarov
  Design of Concrete Structures Using High-Strength Steel Reinforcement mahyarov 0 1,470 10-23-2012, 10:20 AM
Last Post: mahyarov
