Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis DYNAMIC BEHAVIOUR OF FOOTBRIDGES SUBJECTED TO PEDESTRIAN-INDUCED VIBRATIONS
08-08-2014, 04:32 PM
Author: FJALAR HAUKSSON | Size: 2.2 MB | Format: PDF | Quality: Unspecified | Publisher: Copyright © 2005 by Structural Mechanics, LTH, Sweden. Printed by KFS I Lund AB, Lund, Sweden, November, 2005. | Year: 2005 | pages: 118
Over the last years, the trend in footbridge design has been towards greater spans
and increased flexibility and lightness. As a consequence, stiffness and mass have
decreased which has lead to smaller natural frequencies and more sensitivity to
dynamic loads. Many footbridges have natural frequencies that coincide with the
dominant frequencies of the pedestrian-induced load and therefore they have a potential
to suffer excessive vibrations under dynamic loads induced by pedestrians.
The main focus of this thesis was on the vertical and horizontal forces that
pedestrians impart to a footbridge and how these loads can be modelled to be used
in the dynamic design of footbridges. The work was divided into four subtasks. A
literature study of dynamic loads induced by pedestrians was performed. Design
criteria and load models proposed by four widely used standards were introduced
and a comparison was made. Dynamic analysis of the London Millennium Bridge
was performed using both an MDOF-model and an SDOF-model. Finally, available
solutions to vibration problems and improvements of design procedures were studied.
The standards studied in this thesis all propose similar serviceability criteria
for vertical vibrations. However, only two of them propose criteria for horizontal
vibrations. Some of these standards introduce load models for pedestrian loads
applicable for simplified structures. Load modelling for more complex structures,
on the other hand, are most often left to the designer.
Dynamic analysis of the London Millennium Bridge according to British and
International standards indicated good serviceability. An attempt to model the
horizontal load imposed by a group or a crowd of pedestrians resulted in accelerations that exceeded serviceability criteria.
The most effective way to solve vibration problems is to increase damping by installing a damping system. Several formulas have been set forth in order to calculate
the amount of damping required to solve vibration problems. However, more
data from existing lively footbridges is needed to verify these formulas.
  • vardan, slowet, jcbv, gulilero, malc, mgdario, ruaumoko
  The dynamic behaviour of tall buildings bridgeengineer 0 3,366 04-22-2016, 06:42 AM
Last Post: bridgeengineer
  Cyclic Properties of Sand: Dynamic Behaviour for Seismic Applications TAFATNEB 0 1,858 08-12-2014, 01:52 PM
  A Dynamic Response Study on Optimal Piling Depth with respect to Ground Vibrations TAFATNEB 0 1,806 08-12-2014, 01:35 PM
  HUMAN INDUCED VIBRATIONS ON FOOTBRIDGES Application and comparison of pedestrian load TAFATNEB 0 1,767 08-08-2014, 04:26 PM
  Dynamic Behaviour of Concrete Structures subjected to Blast and Fragment Impacts TAFATNEB 0 1,894 08-31-2013, 05:03 PM
  EFFECT OF COMPOSITE ACTION ON THE DYNAMIC BEHAVIOUR OF SPACE STRUCTURES yanburak 0 2,634 09-12-2010, 10:40 PM
Last Post: yanburak
