Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) Advanced Polymer Concretes and Compounds
05-21-2014, 09:44 AM
Author: Oleg Figovsky, Dmitry Beilin | Size: 7.80 MB | Format: PDF | Quality: Original preprint | Publisher: CRC Press | Year: 2014 | pages: 267 | ISBN: 9781466590342
[Image: 79378541212503298441.jpg]
Features
Reflects the newest developments in the rapidly growing field of building materials engineering
Includes a special chapter devoted to new environmentally friendly polymer compounds for monolithic industrial floor coverings and coatings
Assimilates the latest information for industry and puts it into perspective
Deals systematically with polymer matrix concretes
Includes extensive study of the novel types of polymer concrete based on a vulcanized polybutadiene binder and nanostructured organic-silicate matrix
Presents the data on nonisocyanate polyurethane material for monolithic flooring and protective coating—the first nanostructured environmentally friendly polyurethane coatings
Examines specific formulation of the new polymer-based compounds for application in harsh environments—fire-protective coating and coating with high crack-resistant properties
Summary
One way of improving performance attributes of building structures is to use a new class of materials—polymer composites. They have unique properties that combine high strength with features of non-metallic materials. Polymer concretes (PC) appear to offer many possibilities for producing new materials with desired physical and mechanical characteristics, such as improved mechanical strength, low permeability, and greater chemical resistance. Advanced Polymer Concretes and Compounds presents the results of theoretical and experimental research on efficient building material composites based on advanced polymer binders.
This book examines the composition and properties of two new polymer concretes that have potential to solve various construction issues: rubber concrete based on a polybutadiene binder and silicate polymer concrete with an organo-silicate matrix. It examines the physical, mechanical, and technological properties of these PCs as well as their behavior in harsh environments and durability and reliability issues. The authors describe a new environmentally friendly polymer for monolithic industrial floor coverings and coatings—nonisocyanate polyurethanes. They also discuss advanced crack-resistant coatings based on water dispersion of chlorosulfonated polyethylene, which can be used on concrete, metal, and plastic for various industrial uses such as aircraft, automobiles, paint, and in shipbuilding and civil engineering.
The book covers a new type of epoxy composition with nano-heterogenic structure with potential for better mechanical properties and chemical resistance, acid-resistant building materials based on a nanostructured binder, and an advanced environmentally friendly and weather-resistant fire-protective coating for indoor and outdoor application to flammable substrates. With a focus on novel concretes and protective compounds for a variety of environments, this book reflects the newest developments in the rapidly growing field of building materials engineering.
  • bigone, lisine, subin91, ssobhan, PinkPant, vardan, cace-01, Mohammad6299, malc, zrilek, Dell_Brett, sandy1234
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
05-21-2014, 09:51 AM
[-] The following 7 users Like bigone's post:7 users Like bigone's post
  • ssobhan, PinkPant, cace-01, Mohammad6299, gulilero, zrilek, Trishu999
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
05-23-2014, 05:38 PM
[-] The following 3 users Like Mohammad6299's post:3 users Like Mohammad6299's post
  • nima_b12, bridgeengineer, zrilek
  Advanced Polymer Composites for Structural Applications in Construction febo927 2 2,163 06-07-2018, 10:19 PM
