Civil Engineering Association eBooks Structural Books Concrete ciria C660 - Early-Age Thermal Crack Control in Concrete
 AlmostThere
User ID: 46514
Threads: 21
Likes: 101 in 22 posts
Given Likes: 48
07-18-2013, 11:46 AM (This post was last modified: 04-24-2015, 08:48 AM by Dell_Brett.)
CIRIA - C660 - Early-Age Thermal Crack Control in Concrete
Size: - MB | Format: PDF | Quality: Unspecified | Publisher: CIRIA | Year: 2007 | pages: 113 | ISBN: 9788861076602
This guide provides a method for estimating the magnitude of crack-inducing strain and the risk of cracking; and where cracking is predicted guidance is provided on the design of reinforcement to control crack widths. For specific situations where cracking should be avoided, or where the use of reinforcement to achieve acceptable crack widths is uneconomic or impractical, measures are described to minimise the risk including selection of materials and mix design, planning pour sizes and construction sequence, the use of insulation to reduce thermal gradients, the use of movement joints, and cooling of the concrete either prior to placing or in situ.
[-] The following 1 user Likes AlmostThere's post:1 user Likes AlmostThere's post
  â€¢ bigone
 monter
User ID: 31175
Threads: 1
Likes: 664 in 50 posts
Given Likes: 1831
05-04-2015, 10:24 AM
new link for post #1
Uploaded: May/04/2015, File Size: PDF/RAR 7.1/6.8 MB, RAR'd single vector searchable PDF, Pages: 113+155(Appenddices)=268, forum standard pass
[-] The following 22 users Like monter's post:22 users Like monter's post
  â€¢ isurya, PinkPant, oanm2000, gulilero, techno, cristi, dizz, zrilek, mgdario, Dell_Brett, ashcivilea, bridgeengineer, grmetal, sructme, ascetic19, rigid_joint, blaze, ir_71, er.shyams, febo927, Wijono, PanosP
  Ciria - Guide to the Reinforced Construction of Reinforced Concrete in the Arabian Pe Jackass 1 3,996 02-23-2019, 11:34 AM
Last Post: Icivilea
  Crack Analysis in Structural Concrete: Theory and Applications noelda2 8 6,820 07-20-2018, 03:51 AM
Last Post: axcel
  Concrete and Steel Construction: Quality Control and Assurance ibg0203 2 2,540 06-12-2018, 12:04 AM
Last Post: gulilero
  Control of Cracking in Reinforced Concrete Structures rami1976 0 1,753 02-18-2017, 11:26 PM
  Thermal Stresses and Temperature Control of Mass Concrete ir_71 1 2,309 10-17-2016, 11:43 AM
  PCA Design and Control of Concrete Mixtures 15ed. ir_71 0 1,674 03-12-2016, 07:55 PM
  PCA: Design and Control of Concrete Mixtures i_kabir 6 5,744 07-15-2015, 10:48 AM
Last Post: f_slikken
