Civil Engineering Association eBooks Structural Books Steel Structural Steel Design: A Practice Oriented Approach -- Aghayere, Vigil
 psa_1987
Member
User ID: 2943
Threads: 24
Likes: 311 in 19 posts
Given Likes: 43
02-01-2011, 05:39 AM (This post was last modified: 05-11-2012, 05:16 PM by mybest.)
Author: Abi O. Aghayere, Rochester Institute of Technology Jason Vigil, Consulting Engineer | Size: 19.42 MB | Format: PDF | Publisher: Pearson | Year: 2009 | ISBN: 9780132340182
[Image: 58140708809726899591.jpg]
Structural Steel Design: A Practice-Oriented Approach, 1e takes a holistic approach by showing how each individual component design in a steel-framed building is incorporated into a complete building design as one would find in practice. It covers topics that are pertinent to everyday structural design of steel-framed buildings, plus others not commonly found in a text including framing layout, design ‘rules of thumb’, floor vibrations, structural strengthening, and torsion. These key topics are essential to preparing students for designing with structural steel in the real world. This book bridges the gap between theory and practice, helping students learn the basics of steel design and how to practically apply that learning to real-world steel framed building projects.
Key Features
Features practical, real-world examples that include the use of the design aids in the AISC Manual, helping students learn how to use the AISC Manual.
Provides comprehensive coverage of structural loads, including gravity and lateral loads, that is weaved seamlessly into the structural design process allowing for easy calculations of this somewhat complex task.
Includes a chapter on "Practical Considerations" that provides students with a holistic design view and helps reinforce the connection between structural element/member design and building design in practice.
Includes an introduction to floor vibration analysis and design per AISC Design Guide No. 11 as many modern buildings are more susceptible to vibration problems and most textbooks do not cover this topic.
Other topics frequently encountered in practice but aren't covered in other texts include beam copes and their reinforcing; X-braces using tension rods/clevises/turnbuckles; stability bracing of beams and columns; and beam design for uplift loads, strengthening and rehabilitation.
Includes a student steel design project at the end of Chapter 1 with future end-of-chapter problems challenging students to design different components of the building with the concepts learned in each chapter. At the end of the book, students will have completed the design of an entire building helping students tie the design of different building components to the design of an entire building and reinforces a holistic building design approach.
Table of Contents
1. Introduction to Steel Structures
2. Design Methods, Load Combinations, and Gravity Loads
3. Lateral Loads and Systems in Steel Buildings
4. Tension Members
5. Compression Members
6. Non-Composite Beams
7. Composite Beams
8. Beam—Columns
9. Connections —Bolts
10. Connections -Welds
11. Moment Connections
12. Floor Vibrations
13. Built-Up Girders (Plate Girders)
14. Practical Design Considerations in the Design of SteelBuilding
Appendix
[-] The following 85 users Like psa_1987's post:85 users Like psa_1987's post
  • kowheng, Hengki, robertsas, Grunf, dert, ssobhan, pabulumzeng, yanburak, pedzaquino, Dell_Brett, monter, miquan, almadar12, jcoronellr, maad59, Clouseau, we_mbm, civilgr, mowafi3m, ilgar, cace-01, momo2010, vardan, Quantumm, simanta, usman, sodapas, ziggywas1, nuh_civil, Galileo, lamkin, jayborre, Ernest0, jferrer, manoj, zainseiya, zrilek, tluc, dinu69in, davegabj, donaldk, yutt, ibg0203, demertis, killoobilloo, aamirafridi10, Nilupa, baikur, tamboon, lisine, rkce, durga, kmmh76, arceon, foxxx2010, dizz, oanm2000, jjmtz, blaze, NBZ1400, zego2000, dersaar, Jackass, gatob, gulilero, malc, hignacio43, orambo, moh_towhid, jamildear4u, chrono146, i_kabir, slowet, nuttapolk, mgdario, TAFATNEB, rezart, ykhackhack, warbeast, amirdana, bigone, shadabg, nickycruz, joker™, igor1234
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
10-24-2011, 01:43 PM
Other Links:
[-] The following 19 users Like junaid's post:19 users Like junaid's post
  • lisine, oanm2000, Dell_Brett, blaze, zrilek, jcbv, ISTRAKTURA, suchthat, vvvv, orambo, kerenski_t, cristi, Nilupa, davegabj, rezart, ykhackhack, bigone, shadabg, Umer.Aleem
 shaker
User ID: 17336
Threads: 18
Likes: 714 in 73 posts
Given Likes: 537
01-10-2012, 09:20 PM (This post was last modified: 05-11-2012, 05:14 PM by mybest.)
Author: Abi Aghayere, Ph.D., PE, Jason Vigil, PE | Size: 13.3 MB | Format: PDF | Quality: Original preprint | Publisher: Prentice Hall | Year: 2009 | pages: 709 | ISBN: 0-13-234018-6
This book is a comprehensive, stand alone reference for structural steel design. Giving the audience a thorough introduction to steel structures, this book contains all of the need to know information on practical design considerations in the design of steel buildings. It includes complete coverage of design methods, load combinations, gravity loads, lateral loads and systems in steel buildings, and much more.
This is an original pdf copy, not scanned.
[-] The following 21 users Like shaker's post:21 users Like shaker's post
  • Administrator , rezart, malc, gulilero, Dell_Brett, ASEC, Jackass, Albert, coxxxyboy, cardinal85, hoanghiepz, warbeast, GMianG, dovsky, tluc, Nilupa, pabulumzeng, TAFATNEB, ykhackhack, oanm2000, bigone
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
05-11-2012, 05:12 PM
For Dear Mybest,
the Original PDF file.
[-] The following 29 users Like david-smith's post:29 users Like david-smith's post
  • mybest, cace-01, seriousboy, NBZ1400, rezart, Ivan_1980, jcbv, pedzaquino, kowheng, techno, odiclas, Dell_Brett, eliseo.as, ykhackhack, betinnn, isurya, paitaconst, vvvv, blaze, knrsa, oanm2000, eng donny, we_mbm, hignacio43, chenamoy, draluka, shadabg, agelos100, bigone
 junaid
User ID: 402
Threads: 209
Given Likes: 983
10-01-2012, 03:56 PM
[-] The following 11 users Like junaid's post:11 users Like junaid's post
  • 3fan, warlord1, SCREAM7890, jcbv, miquan, dinu69in, Dell_Brett, bigone, ruaumoko, oanm2000, eng donny
01-04-2013, 10:14 AM
PDF : 13.1 mb
[-] The following 6 users Like shadabg's post:6 users Like shadabg's post
  • ting tsai huang, Dell_Brett, jcbv, oanm2000, eng donny, simanta
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
06-13-2013, 10:21 AM
Abi O. Aghayere, Jason Vigil
Year: 2008 Edition: 1 Language: English Pages: 709
[-] The following 7 users Like bigone's post:7 users Like bigone's post
  • simanta, jcbv, isurya, ingchio, Andrew seah, avge, narendra
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2618
12-22-2014, 02:14 PM
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater.  -Albert Einstein
[-] The following 11 users Like amindoxiti's post:11 users Like amindoxiti's post
  • PinkPant, blaze, melekeen, nibbi, bridgeengineer, Trishu999, er.shyams, Dell_Brett, rendel_©, narendra, xpressmusic
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 403
12-22-2014, 08:18 PM
[-] The following 7 users Like Veggeta's post:7 users Like Veggeta's post
  • Trishu999, stigtg, PinkPant, oanm2000, draluka, nexus, bridgeengineer
Likes: 12,075 in 1,233 posts
09-15-2020, 10:54 AM
Structural Steel Design, 3rd Edition
Author(s)/Editor(s): Abi O. Aghayere, Jason Vigil | Size: 44.4 MB | Format: PDF | Quality: Original preprint | Publisher: Mercury Learning & Information | Year: 2020 | pages: 956 | ISBN: 1683923677
[Image: 05652637787486554826.jpg]
Structural Steel Design, Third Edition is a simple, practical, and concise guide to structural steel design – using the Load and Resistance Factor Design (LRFD) and the Allowable Strength Design (ASD) methods -- that equips the reader with the necessary skills for designing real-world structures. Civil, structural, and architectural engineering students intending to pursue careers in structural design and consulting engineering, and practicing structural engineers will find the text useful because of the holistic, project-based learning approach that bridges the gap between engineering education and professional practice. The design of each building component is presented in a way such that the reader can see how each element fits into the entire building design and construction process. Structural details and practical example exercises that realistically mirror what obtains in professional design practice are presented.
Features:
- Includes updated content/example exercises that conform to the current codes (ASCE 7, ANSI/AISC 360-16, and IBC)
- Adds coverage to ASD and examples with ASD to parallel those that are done LRFD
- Follows a holistic approach to structural steel design that considers the design of individual steel framing members in the context of a complete structure.
[-] The following 18 users Like pezhmankhan's post:18 users Like pezhmankhan's post
  • malc, carolinandra, babakfeyzi, jonygut, subin91, kowheng, Dell_Brett, zrilek, civilfafa, PinkPant, jcbv, ali akbar, pedzaquino, rendel_©, oanm2000, lasalleguy, simanta, milova
Pages (2): 1 2 Next »
  Benchmark cases for advanced design of structural steel connection melekeen 1 3,976 06-22-2024, 04:05 AM
  Australia Steel Institute - Design capacity tables for structural steel leong8929 5 6,740 12-26-2022, 10:41 AM
  Structural Steel Design: Jack C. McCormac saqib 20 21,808 11-16-2020, 02:28 PM
Last Post: KMABD
  Structural Steel Drafting and Design adshrt 3 3,799 07-20-2018, 12:58 PM
Last Post: febo927
  Steel Structures: Design and Practice hich 6 7,984 06-14-2018, 09:12 PM
  Applied Structural Steel Design - by Leonard Spiegel usman 3 5,209 06-14-2018, 12:26 PM
Last Post: febo927
  SCI: Fire safe design - A new approach to multi-storey steel framed buildings dinu69in 2 3,042 03-17-2018, 11:03 AM
