Civil Engineering Association eBooks Journals, Papers and Presentations Progressive collapse design of seismic steel frames using structural optimization
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
04-26-2013, 08:02 PM
Author: Min Liu | Size: 1.2 MB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 2011 | pages: 10 | ISBN: --
This paper uses structural optimization techniques to cost-effectively design seismic steel moment frames with enhanced resistance to progressive collapse, which is triggered by the sudden removal of critical columns. The potential for progressive collapse is assessed using the alternate path method with each of the three analysis procedures (i.e., linear static, nonlinear static, and nonlinear dynamic), as provided in the United States Department of Defense United Facilities Criteria (UFC) Design of Buildings to Resist Progressive Collapse. As a numerical example, member sizes of a two-dimensional, nine-story, threebay regular steel immediate moment frame are optimally determined such that the total steel weight is minimized while the design satisfies both AISC seismic provisions and UFC progressive collapse requirements. Optimization results for the example frame reveal that the traditional minimum weight seismic design, which does not explicitly consider progressive collapse, fails to meet the UFC alternate path criteria associated with any analysis procedure. Progressive collapse design optimization using the linear static procedure produces the most conservative and consequently heaviest design against progressive collapse. In contrast, the more accurate nonlinear static and dynamic procedures lead to more economical designs with UFC-acceptable resistance to progressive collapse, at the expenses of considerable modeling and computing efforts.
[-] The following 5 users Like arshiakh's post:5 users Like arshiakh's post
  β€’ Dell_Brett, malc, kowheng, devilmaycry, slowet
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 8,659 08-04-2021, 08:44 PM
Last Post: Wijono
  Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 6,822 03-01-2017, 04:02 PM
Last Post: pezhmankhan
  Structural and Multidisciplinary Optimization bridgeengineer 2 6,535 04-20-2016, 04:58 PM
Last Post: bridgeengineer
  LATBSDC 2013 Conference Advances in Structural Design for Seismic Regions bigone 0 4,058 05-31-2014, 08:09 AM
Last Post: bigone
  Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap TAFATNEB 0 5,101 05-09-2014, 02:00 PM
  Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 4,982 05-09-2014, 11:44 AM
  Progressive Collapse of Bridgesβ€”As pects of Analysis and Design TAFATNEB 0 4,513 05-02-2014, 09:02 AM
