Civil Engineering Association eBooks Journals, Papers and Presentations DISPOSABLE KNEE BRACING: IMPROVEMENT IN SEISMIC DESIGN OF STEEL FRAMES
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
04-06-2013, 06:44 PM
Author: Datio Aristizabal-Ochoa | Size: 550 KB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 1986 | pages: 9
A new and practical technique of lateral bracing for single- and multistory
steel frame construction is presented and discussed. Disposable Knee i
Bracing (DKB) technique, as it is called in this paper, is made up of two struc- :
tural elements, the knee element and the diagonal brace element. The knee (
element is a fuse-like element that dissipates energy by the formation of plastic
flexural hinges at its ends and midspan when the building is subjected to severe
lateral loads. The diagonal brace element, on the other hand, provides the required
level of lateral stiffness and remains in the elastic range at all time. The
knee element is a disposable beam element that can be replaced once its energy
dissipation capacity is utilized. Standard limit analysis of low- and high-rise
steel frames are presented to demonstrate the advantages of the DKB against
traditional bracing and eccentric bracing.
[-] The following 10 users Like asim99's post:10 users Like asim99's post
  â€¢ jcbv, faros3000, Dell_Brett, kowheng, ting tsai huang, malc, devilmaycry, tluc, slowet, sodapas
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 8,659 08-04-2021, 08:44 PM
Last Post: Wijono
  Influence of Structural Parame ters to the Seismic Collapse Resistance of RC Frames i TAFATNEB 0 4,138 04-18-2014, 05:39 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 5,266 04-11-2014, 09:13 AM
  Seismic response of steel frames containing hierarchical frictiondissipating joints TAFATNEB 1 5,093 11-28-2013, 12:08 PM
  Seismic performance of RC frames with concentric internal steel bracing arshiakh 1 5,636 11-28-2013, 12:04 PM
  Seismic Analysis and Design of Steel Liquid Storage Tanks TAFATNEB 0 3,989 08-31-2013, 11:08 AM
  SEISMIC LATERAL FORCE DISTRIBUTION FOR DUCTILITY-BASED DESIGN OF STEEL PLATE SHEAR WA TAFATNEB 0 4,175 08-31-2013, 10:41 AM
