Civil Engineering Association Forum Discussion Suggestion & Complains Archive Report Any Bug here
Thread Closed
Report Any Bug here
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,197 in 2,356 posts
Given Likes: 4260
#621
01-25-2016, 05:15 AM
(01-24-2016, 10:12 PM)rami1976 Wrote: Dear Admin
when trying to upload pictures , i select the desired pictures through the uploader , after i press upload , i got a message :
"General Notice
Please go back and select at least one image file to upload."
i tried to re upload , it gave me the same message.
regards
I think this is your local problem I try to upload picture from several computers to "pic.civilea.com" and all them were successful.
please try again in other PC or browsers and tell me the result.
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1388
#622
04-21-2016, 12:06 PM
Dear Admin
if i press on my user name to check my profile , an error use to display for a little time then it disappear ( as follows)
[Image: 58247333536468474673.jpg]
[-] The following 1 user Likes rami1976's post:1 user Likes rami1976's post
  • Administrator
 Dobblo
South Africa
User ID: 44024
Threads: 9
Likes: 319 in 31 posts
Given Likes: 43
#623
05-23-2016, 12:18 PM
Dear admin
When generating ebook post in postgen, I select "Source type" as "Scanner (OCR)", but when the postgen generates a code, it generates it as "Scanner". I then have to add the OCR bit myself.
Also, maybe it would be good to have 2 separate fields for ISBN and ISBN-13 so that both can be put in if they are available.
Thank you.
[-] The following 1 user Likes Dobblo's post:1 user Likes Dobblo's post
  • Administrator
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,322 in 678 posts
Given Likes: 1667
#624
08-05-2016, 12:11 PM
Dear Admin
the problem in post #605 still as it is
👉 CLICK HERE 👈
the problem was about (PREVIEW POST ) Button
thanks in advance
 mmg2200
User ID: 1484
Threads: 0
Likes: 0 in 0 posts
Given Likes: 6
#625
01-19-2017, 10:43 AM
links are not working in the below forms
http://forum.civilea.com/thread-2113.html
http://forum.civilea.com/thread-2325.html
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,118
Likes: 30,986 in 4,091 posts
Given Likes: 612
#626
01-19-2017, 12:03 PM
This is not a bug. I don't know what you want and what are you doing in our forum. Registered almost 8 years ago and you report dead links by using report twice. Learn to read before using the report. Do you see dead links as a reason ?
[Image: 51326240498695521542.jpg]
Do you realy think a dead link is a bug and for this reason you post here this post including 2 transparent links.
You can't ask as thousands members for years a new link in the right thread ?
If someone breaks forum rules, post spam content and post in wrong forum it's only you.
And i don't use report, i warn and if an user can't learn after some warning i ban.
  • oanm2000, usman, Dell_Brett
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Given Likes: 4260
#627
02-13-2017, 12:24 PM
This topic was closed.
You can continue here:
http://forum.civilea.com/thread-53974.html
Pages (63): « Previous 1 … 54 55 56 57 58 59 60 61 62 63
