11-13-2013, 12:30 PM
11-13-2013, 12:31 PM
(11-13-2013, 11:15 AM)lisine Wrote: There is some trouble with mirror formatting code when multiple links are posted. there is no probkem here.
11-14-2013, 05:05 PM
(11-13-2013, 09:11 AM)mowafi3m Wrote: the links became hidden and alive !!! (11-13-2013, 12:30 PM)Administrator Wrote: Solvedsolved partially check this thread /post#2 Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
11-14-2013, 07:38 PM
the same problem in post#3
11-14-2013, 08:58 PM
The problem is with the mirror code. The second example was corrected by editing and replacing mirror with code. The same problem was with code before solved by Admin so we must wait to him to correct this one too.
11-14-2013, 09:25 PM
I agree with you Eng.BennyP
but the section name is ( report any bug here ) I posted that only to help our staff not for other thing if my action annoyed you , I 'm sorry for that and I will stop thank you
11-15-2013, 03:39 AM
Why? I only checked and searched the reason for helping to resolve faster this issue. No need to apologize for a legitime action. This section is for reporting bugs so every report will help. Finally we will correct every post but I checked and corrected one example leaving the other for Admin to see it and resolve.
11-15-2013, 05:36 AM
Irror code is a custom code tag and it is not a default code of MYBB script.
After upgrading forum script this problem occured. Also you can see mirror buttom is not located ain editor too. We are working on it. Thanks for your report, any report help us to find bugs fast and solve it.
11-16-2013, 06:12 AM
(11-14-2013, 05:05 PM)mowafi3m Wrote: solved partially SOLVED Example: [MIRROR]Content of this section is hidden, You must be registered and upgrade your account to see this content. [/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽 See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
11-20-2013, 09:34 AM
(This post was last modified: 11-20-2013, 09:35 AM by pezhmankhan.)
Hi,
Every time that I try to send private message I got this error, the waiting time changed.
