06-13-2016, 06:31 AM
Slope stability analyses using limit equilibrium and strength reduction methods
- Author(s): Zoran Berisavljević, Dušan Berisavljević, Vladimir Čebašek, Dragoslav Rakić
- Published By: GRAĐEVINAR
- Published Year: 10/2015
- DOI: 10.14256/JCE.1030.2014
- Size: 592 KB
- Quality: Unspecified
- Abstract: This paper presents results of comparative slope stability analyses conducted by limit equilibrium and strength reduction methods. Several slopes, taken either from geotechnical practice or literature review, are considered. The influence of tension, distributed load, finite element size and model parameters is analysed in relation to the location, shape of the critical failure surface and the corresponding value of the factor of safety. Both methods provide similar results if they are correctly applied using appropriate software programs.
Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation:
👉 CLICK HERE 👈
