Civil Engineering Association Software Software Product Csi Products PERFORM 3D Perform3D v5
Perform3D v5
 KhaLed-S.E
Egypt
User ID: 48176
Threads: 39
Likes: 1,063 in 98 posts
Given Likes: 490
#11
12-28-2012, 02:29 AM
PERFORM 3D V5.0.0 (installation only)
Big Thank To jokerβ„’
πŸ‘‰ CLICK HERE πŸ‘ˆ
[-] The following 11 users Like KhaLed-S.E's post:11 users Like KhaLed-S.E's post
  β€’ malc, jokerβ„’, blaze, Dell_Brett, mahyarov, ykhackhack, Hengki, bigone, rezart, levanduy, mecheil.edwar
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,118
Likes: 30,986 in 4,091 posts
Given Likes: 612
#12
02-06-2013, 06:20 PM (This post was last modified: 02-08-2013, 03:32 PM by BennyP.)
CSI Perform 3D 5.0 | 210.7 mb
Posted in Lavteam and grabbed by someone to other share sites. Downloaded for checking the solution and as i guessed the solution is the same as in our site (License generator for CSI products) and for sure grabbed from here. Anyway, we live in a global world so we all use the same sources.
[-] The following 9 users Like BennyP's post:9 users Like BennyP's post
  β€’ ykhackhack, aslam, KhaLed-S.E, bigone, jokerβ„’, rezart, jcbv, TAFATNEB, mecheil.edwar
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
#13
02-14-2013, 12:21 AM
CSI Perform 3D v5.0.0
[Image: 01959791050930464503.jpeg]
[Image: 29382619599264471025.jpeg]
PERFORM-3D is an ideal tool for nonlinear performance-based analysis and design, created by Dr. Graham H. Powell, University of California at Berkeley Professor Emeritus of Civil Engineering.
PERFORM-3D is a structural-engineering software useful for the performance assessment of structural systems. State-of-the-art constitutive-modeling capabilities enable characterization of material nonlinearity, including strength and stiffness degradation during component-level hysteresis. Analysis capabilities also extend to geometric nonlinearity and effects associated with P-Delta behavior. Advanced modeling tools enable a sophisticated simulation of structural behavior. Components may be grouped according to type, location, and limit state before evaluation proceeds in terms of strength or deformation-based demand-capacity ratio. The dynamic display of D-C usage is available through color-coordinated time-history animations.
PERFORM-3D version 5 Enhancements:
- A 64-bit version of the analysis engine is now utilized when Peform-3D is installed on a 64 bit computer. The 32-bit analysis engine is still used on 32-bit computers. The 64-bit engine allows larger problems to be solved, and tends to run faster than the 32-bit engine.
- A large-capacity eigenvalue routine has been added. In earlier versions, the eigenvalue routine could not accommodate structures with very large numbers of mass points. The new eigenvalue routine (the same as in SAP2000) allows a larger number of mass points than was previously possible.
- Warnings are now provided when an unstable or ill-conditioned stiffness matrix is detected. When an analysis model is set up for a complex structure, a common problem is that the model may be poorly conditioned numerically, or may be unstable. For an explanation of the causes of poor conditioning and instability, see the book Modeling for Structural Analysis: Behavior and Basics, by Powell, Chapter 3, especially Section 3.5, available from CSi.
- Formal documentation is now provided describing the format of the binary results files. For each analysis, Perform-3D writes the analysis results in a number (often a large number) of short binary files. Many users access these binary files directly, to add post-processing operations that are not included in the graphical user interface.
- The number of modes shapes printed in the text file M000.txt can now be specified. In earlier versions, all mode shapes were printed in this file, and for a large structure the file could be very large. Usually the number now specified will be zero, so that detailed mode shapes are not printed, and the M000.txt file will be quite short.
- The analysis logs for each Analysis Series are now written to separate files, making them more manageable. In earlier versions, a log of each analysis in the series is also included in ECHO.txt, showing details of the analysis, the computation time for each analysis step, and an energy balance. For a large structure, this made the ECHO.txt file very long
[Image: homepage.png]
[-] The following 10 users Like Dell_Brett's post:10 users Like Dell_Brett's post
  β€’ Sumatra, ykhackhack, blaze, rezart, erthqkengnrβ„’, jcbv, bigone, zuhalz, TAFATNEB, mecheil.edwar
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
#14
05-03-2013, 11:33 PM
[MIRROR]Content of this section is hidden, You must be registered and upgrade your account to see this content.
[/MIRROR] πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½πŸ”½
[-] The following 11 users Like ykhackhack's post:11 users Like ykhackhack's post
  β€’ Quantumm, zrilek, Dell_Brett, shadabg, rezart, malc, bigone, devilmaycry, sodapas, TAFATNEB, civilgen
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,322 in 678 posts
Given Likes: 1667
#15
11-13-2013, 12:21 PM
PERFORM 3D V5.0.1
crack
[-] The following 17 users Like mowafi3m's post:17 users Like mowafi3m's post
  β€’ Dell_Brett, ssobhan, TAFATNEB, malc, bigone, zrilek, ykhackhack, Rami11, chenamoy, oguzhan aydinli, yutt, terrorruban, jcbv, Andrew seah, simanta, civilgen, Williams
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
#16
11-14-2013, 06:05 AM
PERFORM 3D V5.0.1 setup only
From LAVteam
[-] The following 9 users Like bigone's post:9 users Like bigone's post
  β€’ jcbv, TAFATNEB, mowafi3m, learner20, zrilek, strengbas, terrorruban, blaze, mecheil.edwar
 ASEC
Semi Senior Member
United States
User ID: 13344
Threads: 11
Likes: 397 in 113 posts
Given Likes: 298
#17
05-11-2015, 01:54 PM
Anyone has a copy of the file in post #3 to extend the expiry date mine is going to expire in a couple of days. That will be very much appreciated.
[-] The following 1 user Likes ASEC's post:1 user Likes ASEC's post
  β€’ ykhackhack
 KhaLed-S.E
Egypt
User ID: 48176
Threads: 39
Given Likes: 490
#18
06-02-2015, 08:53 AM
@+ASEC
[-] The following 14 users Like KhaLed-S.E's post:14 users Like KhaLed-S.E's post
  β€’ blaze, PinkPant, Dell_Brett, zrilek, ASEC, ykhackhack, jcbv, ensarsaid, oanm2000, stigtg, malc, bigone, mecheil.edwar, Andrew seah
 ensarsaid
User ID: 99758
Threads: 1
Likes: 2 in 1 posts
Given Likes: 7
#19
12-01-2015, 11:14 PM
Medicine please;
  β€’
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1388
#20
07-18-2016, 11:50 PM
CSI PERFORM-3D v5.0.1
[Image: 86933931334380809924.jpg]
CSI PERFORM-3D was designed for nonlinear analysis and performance assessment for 3D structures.
Displacement Based Design
Β  Traditionally, earthquake-resistant design has been strength-based, using linear elastic analysis.
Β  Since inelastic behavior is usually allowed for strong earthquakes, this is not entirely rational.
Β  Strength-based design considers inelastic behavior only implicitly.
Β  Displacement-based (or deformation-based) design considers inelastic behavior explicitly, using nonlinear inelastic analysis.
Β  Displacement-based design recognizes that in a strong earthquake, inelastic deformation (or ductility) can be more important than strength.
Β  PERFORM-3D allows you to use displacement-based design.
Implementation of ASCE 41
Β  Procedures for displacement-based design using inelastic analysis are specified in ASCE 41, ”Seismic Rehabilitation of Existing Buildings”.
Β  ASCE 41 applies to the retrofit of existing buildings, but the procedures can be applied to the design of new buildings.
Β  PERFORM-3D implements the procedures in ASCE 41.
Β  However, PERFORM-3D is a general tool for implementing displacement-based design. It is not limited to ASCE 41.
Capacity Design
Β  The response of a structure to earthquake ground motion, whether elastic or inelastic, is highly uncertain.
Β  Capacity design is a rational way to improve the response of a structure in a strong earthquake, by deliberately controlling its behavior.
Β  Capacity design controls the inelastic behavior of a structure, by allowing inelastic behavior only in locations chosen by the designer. In these locations the structural components are designed to be ductile. The rest of the structure remains essentially elastic, and can be less ductile.
Β  Controlling the behavior in this way improves reliability, reduces the amount of damage, and can reduce construction costs.
Β  PERFORM-3D allows you to apply capacity design principles.
What PERFORM-3D is NOT
Β  - PERFORM-3D has powerful capabilities for inelastic analysis, but it is not intended for general purpose nonlinear analysis.
Β  If you have no idea how your structure will behave when it becomes inelastic in a strong earthquake, PERFORM-3D can probably help you to identify the weak points, and hence can guide you in improving the design.
Β  However, PERFORM-3D is not intended for ”design by analysis”, where the engineer expects the analysis to determine exactly how a structure will behave. Β
Β  PERFORM-3D is a powerful tool for implementing displacement-based design and capacity design. It will help you to produce better designs, but it will not do the engineering for you.
Unrar and install the application.
Use applied keygen. A license file - lservrc (without an extension) will be generated.
Copy it to the folder:<installdir>\PERFORM\PERFORM-3D\Program\
Thanks To Lavteam
[-] The following 16 users Like rami1976's post:16 users Like rami1976's post
  β€’ malc, Dell_Brett, amindoxiti, promo8, oanm2000, mecheil.edwar, blaze, slowet, PinkPant, zrilek, simanta, jokerβ„’, temp1366, eng donny, Jackass, faros3000
  Perform3D v11 poolmand 0 493 06-21-2026, 06:40 AM
  Perform3D v10 babakfeyzi 2 2,842 12-14-2024, 09:22 PM
Last Post: babakfeyzi
  Perform3D v9 Arigato 1 3,155 05-07-2023, 08:10 AM
Last Post: zrilek
  Perform3D v8 temp1366 5 8,507 11-09-2022, 12:08 PM
Last Post: jumbo13
  Perform3D v7 jokerβ„’ 6 12,752 06-11-2020, 05:36 AM
  Perform3D v6 temp1366 3 10,275 12-22-2017, 06:47 PM
Last Post: zipatton
  Perform3D v4 timosiβ„’ 5 12,208 05-13-2016, 10:22 AM
Last Post: rezart
