Civil Engineering Association Software Software Product Csi Products Bridge Csi Bridge V15
Csi Bridge V15
 fthor
Newbie
Banned
User ID: 2230
Threads: 0
Likes: 18 in 3 posts
Given Likes: 2
#11
05-12-2011, 02:07 AM (This post was last modified: 05-12-2011, 02:54 AM by kowheng.)
Hello, Full crack CSIBridge. Build the file and paste it to the folder. Take. lic to the file.
πŸ‘‰ CLICK HERE πŸ‘ˆ
[-] The following 12 users Like fthor's post:12 users Like fthor's post
  β€’ cheo.smith, betinnn, knrsa, vardan, Hengki, seriousboy, davegabj, sujups, blaze, zrilek, techno, ebaturalp
 ramyoooo
User ID: 22380
Threads: 0
Likes: 27 in 2 posts
Given Likes: 2
#12
05-14-2011, 11:35 PM (This post was last modified: 05-15-2011, 12:13 AM by Dell_Brett.)
this full crack
the method to create lservrc as follow:
1-go to folder CSiBridge 15 on program files
change lservrc to lservrc.lic
2-copy 3 files licence to folder CSiBridge 15 on program files
3-run CSIBridge 15.bat
4-run echoid.exe & type last 5 symbols in code 1 to code in CSIBridge 15.bat
such as :23A21 & press enter
5-type period one year & press enter
6- it will create lservrc.lic change to lservrc
[-] The following 15 users Like ramyoooo's post:15 users Like ramyoooo's post
  β€’ sujups, blaze, mgdario, zrilek, Vincwilson, tremonti, ha893459, LadaHitam, techno, ebaturalp, piscesa, oanm2000, sathish, amiboyz, relu59
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
#13
06-22-2011, 08:59 AM
CSiBridge v15.0.0
DIRECT LINKS thumbup
No limits to creativity
[-] The following 2 users Like jokerβ„’'s post:2 users Like jokerβ„’'s post
  β€’ zrilek, milvio
 eveningstar
Vietnam
User ID: 31380
Threads: 4
Likes: 65 in 7 posts
Given Likes: 3
#14
07-09-2011, 03:05 AM
[Image: 67245083527189241328.jpg]
Significant New Features
- Built-in European concrete and steel material properties.
- Display and output of frame stresses.
- Load optimization feature to determine the optimal loading scale factors to achieve goals and limits on displacement and force response throughout the structure.
- Canadian NBCC 2010 loading for wind, seismic, and response-spectrum.
- American ASCE-7 loading for wind, seismic, and response-spectrum.
- Italian NTC 2008 response-spectrum functions with geographic database.
- Specialized bridge groups may now be specified within each bridge object. Each bridge group applies to a particular type of component (slab, girder, bearing, etc.) and an individual bridge object. Depending on the bridge group type, groups may be defined for multiple items, multiple longitudinal ranges, and/or multiple transverse ranges.
- The specification of rebar for the bridge object superstructure has been enhanced. Distances are now measured along each individual girder. Longitudinal rebar is located relative to the center of the supports or the centers of the girder spans, and shear rebar is located relative to the ends of each girder span.
- A new design request type has been added for steel I-girder composite bridge superstructures to account for the constructability check according to the "AASHTO LRFD 2007" code, including the 2008 interim provisions. Composite and non-composite behavior can both be considered, with or without using staged-construction analysis.
- Bridge load rating has been added for steel I-girder composite bridge superstructures according to the AASHTO "Manual for Bridge Evaluation", First Edition, 2008. Separate rating requests are provided for the service and strength checks of both composite and non-composite superstructures. Live-load distribution factors can be automatically calculated using code formulae, specified by the user, or determined from a detailed 3-D live-load analysis.
- For flexural-strength superstructure design checks by the AASHTO LRFD 2007 code, the effect of user-specified reinforcement is now included for the prestressed box-girder and precast-girder composite sections. Previously only the effect of the concrete and tendons were included in these checks. The effect of reinforcement for the slab of steel-girder composite sections was already being considered.
- Design checking has been implemented for concrete superstructure sections according to the Canadian "CAN/CSA-S6-06" code. Superstructure types supported include prestressed concrete box girders and composite sections with precast I-girders and U-girders. Separate design checks are provided for stress, flexural strength, and shear strength using MCFT (modified compression field theory). The effect of mild reinforcing is included as well as the prestress tendons. Live-load distribution factors can be automatically calculated using code formulae, specified by the user, or determined from detailed 3-D live-load analysis.
- Automated load combinations and design load types have been added as required for bridge design according to the Canadian code CSA-S6-06.
- Canadian steel frame building design code CSA S16-2009.
- Other minor enhancements.
[-] The following 24 users Like eveningstar's post:24 users Like eveningstar's post
  β€’ vsa2010, Galileo, mecheil.edwar, kowheng, haiquyppl1984, ibg0203, milvio, zrilek, ali akbar, warbeast, faros3000, khang02, TAFATNEB, melkat, bhawk0, oanm2000, Dell_Brett, kaungthant, faxel, blaze, Rami11, rezart, GORJAN, Pajipitar
Threads: 57
07-09-2011, 05:11 AM (This post was last modified: 01-01-2012, 02:03 AM by kowheng.)
[Image: 64156539254857457623.jpg]
Mirror Links: [email protected] MB
Enterupload
Filesonic
Fileserve
10upload
Megaupload
Cramit
Notes: Use previous CSI License Generator (Latest Update)
[-] The following 52 users Like kowheng's post:52 users Like kowheng's post
  β€’ haiquyppl1984, mecheil.edwar, ibg0203, bhawk0, vardan, Jackass, pezhmankhan, jcbv, versiondemo, milvio, MEKKAWI, zrilek, seriousboy, Mouh@ndiss, orambo, hcardenas, tremonti, warbeast, aslam, malc, pingfan2, mgdario, eveningstar, simanta, fdgTG67, faros3000, bigone, ha893459, khang02, attila, TAFATNEB, arceon, nuh_civil, melkat, oanm2000, Dell_Brett, kamran, kaungthant, faxel, Adam Smith, blaze, ChisTeam, slowet, Rami11, piyush86, u4406014, Galileo, rezart, 3fan, smail, Clouseau, shark
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,118
Likes: 30,986 in 4,091 posts
Given Likes: 612
#16
07-09-2011, 01:05 PM
Download and use 7zip (free):
[-] The following 7 users Like BennyP's post:7 users Like BennyP's post
  β€’ milvio, warbeast, simanta, malc, rezart, 3fan, ting tsai huang
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
#17
08-19-2011, 10:55 PM
HotFile Mirror
[-] The following 13 users Like jokerβ„’'s post:13 users Like jokerβ„’'s post
  β€’ ibg0203, chenamoy, milvio, oanm2000, Dell_Brett, zrilek, kaungthant, mohcivil, u4406014, rezart, kami, blaze, Clouseau
 unix0123
User ID: 14411
Threads: 1
Likes: 99 in 15 posts
Given Likes: 55
#18
08-21-2011, 12:31 AM
Here it is the direct link:
[-] The following 17 users Like unix0123's post:17 users Like unix0123's post
  β€’ jokerβ„’, faros3000, llbb, pmg814, Dell_Brett, rezart, oanm2000, zrilek, kaungthant, milvio, davegabj, Arigato, jcbv, blaze, Rami11, piyush86, Galileo
Threads: 57
08-21-2011, 03:25 AM (This post was last modified: 01-01-2012, 01:38 AM by kowheng.)
Stand alone V15.0.1 patch from V15.00
ZIP 46.65 MB
[-] The following 15 users Like kowheng's post:15 users Like kowheng's post
  β€’ aslam, jokerβ„’, Dell_Brett, oanm2000, kaungthant, zrilek, yamacdere, azas, kln258, blaze, mohcivil, Galileo, rezart, ha893459, Clouseau
Threads: 57
08-21-2011, 04:38 AM (This post was last modified: 01-01-2012, 01:42 AM by kowheng.)
Single ZIP file: Stand Alone V15.10
ZIP 631 MB
[-] The following 12 users Like kowheng's post:12 users Like kowheng's post
  β€’ Dell_Brett, hrezaei, oanm2000, kaungthant, zrilek, liamsi, rezart, malc, slowet, Galileo, 3fan, Clouseau
