Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Reports and Photos from "nisee.berkeley.edu"
[Request] Reports and Photos from "nisee.berkeley.edu"
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
#151
08-13-2013, 09:55 AM
Development and evaluation of improved details for ductile welded unreinforced flange connections
👉 CLICK HERE 👈
[-] The following 4 users Like arshiakh's post:4 users Like arshiakh's post
  â€¢ malc, ssobhan, fred2010, kowheng
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
#152
09-02-2013, 06:46 PM
  • Article/eBook Full Name: Dynamic interaction factors for floating pile groups
  • Author(s): Gazetas, George
  • Related Links:
    👉 CLICK HERE 👈
  • Article/eBook Full Name: Kinematic bending moments in seismically stressed piles
  • Author(s): Nikolaou, A.; Mylonakis, George; Gazetas, George
  • Related Links:
    👉 CLICK HERE 👈
[-] The following 1 user Likes ssobhan's post:1 user Likes ssobhan's post
  â€¢ vangjo
 arshiakh
User ID: 37777
Threads: 97
Given Likes: 214
#153
09-04-2013, 04:33 AM
👉 CLICK HERE 👈
  â€¢ shadabg, ssobhan, vangjo, malc
Threads: 274
Likes: 12,075 in 1,233 posts
05-14-2014, 08:37 AM
  • Article/eBook Full Name: A combined isolation system for the Wellington Hospital in Wellington, New Zealand, and a new type of isolation device
  • Author(s): Zhao, John X.; Robinson, William H.
  • Publish Date: 2009
  • Related Links:
    👉 CLICK HERE 👈
  â€¢
 arshiakh
User ID: 37777
Threads: 97
Given Likes: 214
#155
05-14-2014, 12:13 PM
Author: Zhao, John X.; Robinson, William H. | Size: 895 KB | Format: PDF | Quality: Unspecified | Publisher: NISEE e-Library | Year: 2009 | pages: 9
ellington Fault, capable of producing an earthquake of magnitude 7.5 and with an average return period of 700 years, passes through Wellington city. Only a few kilometres from the fault surface trace, a regional hospital was built during 2004-2009. To achieve an objective that the hospital must function normally immediately after a large earthquake along the Wellington Fault, the hospital building was seismically isolated, and a relatively low baseshear coefficient and a very large design displacement were required. The building is a moment-resisting reinforced concrete frame structure and the vertical load at the base of each column ranges from 400kN to just over 4000kN. The relatively low vertical load poses a great design difficulty in achieving a satisfactory stability safety factor with a reasonable cost for the lead rubber bearings. We proposed a combined isolation system for this building, consisting of friction sliding devices for those columns with a light vertical load and lead rubber bearings for the other columns. The combined system has a maximum design displacement of 600mm and our test results show that there is a satisfactory stability safety factor. To overcome similar design difficulties, Robinson Seismic Ltd. has developed a new isolation system - RoGlider. Some test results and an application of RoGlider for a single storey hospital in New Zealand are presented. The paper also presents the analyses of testing results for a pair of lead rubber bearings under extreme horizontal displacement and demonstrates a possible mechanism for the negative stiffness developed during the unloading and reloading phase of the test.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 7 users Like arshiakh's post:7 users Like arshiakh's post
  â€¢ ssobhan, pezhmankhan, Dell_Brett, malc, Mohammad6299, blaze, zrilek
 miquan
Vietnam
User ID: 631
Threads: 171
Likes: 3,748 in 387 posts
Given Likes: 1331
#156
06-06-2014, 03:06 AM
  • Article/eBook Full Name: Water pressures on dams during earthquakes
  • Author(s): Westergaard, Harold M.
  • Related Links:
    👉 CLICK HERE 👈
  • Article/eBook Full Name: Seismic design of bridge abutments and retaining walls
  • Author(s): Wood, J. H.; Elms, D. G.
  • Related Links:
    👉 CLICK HERE 👈
  â€¢
 ssobhan
User ID: 1054
Threads: 224
Given Likes: 2465
#157
06-06-2014, 09:14 AM
👉 CLICK HERE 👈
[-] The following 2 users Like ssobhan's post:2 users Like ssobhan's post
  â€¢ Mohammad6299, zrilek
 sia1
User ID: 2076
Threads: 10
Likes: 117 in 15 posts
Given Likes: 117
#158
06-06-2014, 11:00 AM
Author: Westergaard, Harold M. | Size: 4.6 MB | Format: PDF | Quality: Unspecified
👉 CLICK HERE 👈
[-] The following 10 users Like sia1's post:10 users Like sia1's post
  â€¢ Mohammad6299, miquan, arshiakh, ssobhan, zrilek, malc, ashcivilea, blaze, RyanRS, bridgeengineer
 arshiakh
User ID: 37777
Threads: 97
Given Likes: 214
#159
06-06-2014, 12:59 PM
Author: Wood, J. H.; Elms, D. G. | Size: 2.2 MB | Format: PDF | Quality: Unspecified | Publisher: NISEE e-Library | Year: 1990 | pages: 97
Report reviews findings from a series of research projects related to the seismic design of soil retaining walls. The behavior of retaining walls under earthquake loading has been studied by experimental and theoretical (analytical) investigations of both free standing walls and walls that are rigidly connected to a major structure such as a bridge abutment. Free standing walls, ranging from rigid to walls that can respond by outward sliding on soil failure planes have been investigated. Analysis and design procedures for special forms of construction, including reinforced earth and tied-back walls have been developed.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 8 users Like arshiakh's post:8 users Like arshiakh's post
  â€¢ ssobhan, miquan, zrilek, Mohammad6299, sia1, malc, blaze, temp1366
 Badis
Senior Member
User ID: 16671
Threads: 53
Likes: 2,308 in 169 posts
Given Likes: 221
#160
06-30-2014, 02:29 AM
Looking for this document.
  • Article/eBook Full Name: Axial - shear - flexure interaction approach for displacement-based evaluation of reinforced concrete elements
  • Author(s): Mostafaei, Hossein
  • Related Links:
    👉 CLICK HERE 👈
[-] The following 1 user Likes Badis's post:1 user Likes Badis's post
  â€¢ ssobhan
Pages (23): « Previous 1 … 11 12 13 14 15 16 17 18 19 20 21 … 23 Next »
  [REQUEST] Some useful seismic reports miquan 4 3,864 07-14-2015, 01:58 PM
Last Post: atram
