Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Reports and Photos from "nisee.berkeley.edu"
[Request] Reports and Photos from "nisee.berkeley.edu"
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
#111
11-20-2012, 12:13 PM (This post was last modified: 11-20-2012, 12:21 PM by ssobhan.)
Hi
Please share this document;
Preliminary experimental investigation of a broad base liquid storage tank
Bouwkamp, Jack G.; Kollegger, Johann P.; Stephen, Roy M.
UCB/EERC-81/06, Earthquake Engineering Research Center
👉 CLICK HERE 👈
Response of a Cylindrical Liquid Storage Tank to Static and Dynamic Lateral Loads
Manos, George C.; Clough, Ray W.
👉 CLICK HERE 👈
thanks
  â€¢
 atram
User ID: 34120
Threads: 29
Likes: 236 in 48 posts
Given Likes: 436
#112
11-20-2012, 01:37 PM (This post was last modified: 11-20-2012, 01:37 PM by atram.)
here are they:
👉 CLICK HERE 👈
[-] The following 3 users Like atram's post:3 users Like atram's post
  â€¢ ssobhan, zrilek, shadabg
 kgelling
User ID: 19489
Threads: 5
Likes: 36 in 8 posts
Given Likes: 66
#113
12-04-2012, 07:04 PM
Is it possible to get this article? It would be very appreciated as is for a doctoral thesis.
Thanks in advance.
The Earthquake Engineering Online Archive - (Nisee e-library)
Local bond stress-slip relationships of deformed bars under generalized excitations
Eligehausen, Rolf; Popov, Egor P.; Bertero, Vitelmo V.
Available online:
👉 CLICK HERE 👈 (6 MB)
  â€¢
 hich
User ID: 3732
Threads: 94
Likes: 5,003 in 418 posts
Given Likes: 101
#114
12-05-2012, 07:49 AM
Author: Eligehausen, Rolf; Popov, Egor P.; Bertero, Vitelmo V | Size: 6 MB | Format: PDF | Quality: Unspecified | Publisher: Nisee
This report covers integrated experimental and analytical investigations that permit predicting analytically the local bond stress-slip relationship of deformed reinforcing bars subjected to generalized excitations, such as may occur during the response of reinforced concrete (R/C) structures to severe earthquake ground motions. Some 125 pull-out specimens were tested. Each of these specimens simulated the confined region of a beam-column joint. Only a short length (five times the bar diameter) of a Grade 60 deformed reinforcing bar was embedded in confined concrete. The tests were run under displacement control by subjecting one bar end to the required force needed to induce the desired slip which was measured at the unloaded bar end. The influence of the following parameters on the bond stress-slip relationship was studied: (1) loading history, (2) confining reinforcement, (3) bar diameter and deformation pattern, (4) concrete compressive strength, (5) clear bar spacing, (6) transverse pressure, and (7) loading rate. The detailed experimental results are presented and compared with results given in the literature. Based on the experimental results obtained, a relatively simple analytical model for the local bond stress-slip relationship of deformed bars embedded in confined concrete is developed. The model takes into account the significant parameters that appear to control the behavior observed in the experiments. The main assumption is that bond deterioration during generalized excitations depends on the damage experienced by the concrete which, in turn, is a function of the total dissipated energy. This assumption appears to apply only in the range of low-cycle fatigue; that is, when a small number of cycles at relatively large slip values is applied. The concrete in R/C joints of ductile moment resisting frames outside of stirrup-ties is unconfined. Therefore, based on the evaluation of test data given in literature, the analytical model is modified to include such regions. Furthermore, rules are formulated to extend the validity of the model to conditions different from those present in the tests. The results of the investigation reported are used to offer conclusions regarding the behavior of bond of deformed bars under monotonic and cyclic loading, and recommendations for further work are indicated.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 7 users Like hich's post:7 users Like hich's post
  â€¢ kowheng, ssobhan, Dell_Brett, lisine, mary, malc, kgelling
Threads: 274
Likes: 12,075 in 1,233 posts
12-10-2012, 07:07 AM
Dear Friends,
I need this report:
👉 CLICK HERE 👈
Thanks for your attention.
  â€¢
 ssobhan
User ID: 1054
Threads: 224
Given Likes: 2465
#116
12-10-2012, 08:55 AM
Dear pezhmankhan
Here get it;
👉 CLICK HERE 👈
[-] The following 1 user Likes ssobhan's post:1 user Likes ssobhan's post
  â€¢ pezhmankhan
 ssobhan
User ID: 1054
Threads: 224
Given Likes: 2465
#117
01-24-2013, 12:37 PM (This post was last modified: 01-24-2013, 12:38 PM by ssobhan.)
Dear friends
Please share this report;
Experimental evaluation of seismic design methods for broad cylindrical tanks
👉 CLICK HERE 👈
  â€¢
 atram
User ID: 34120
Threads: 29
Given Likes: 436
#118
01-24-2013, 12:53 PM (This post was last modified: 01-24-2013, 12:55 PM by atram.)
(01-24-2013, 12:37 PM)ssobhan Wrote: Dear friends
👉 CLICK HERE 👈
here it is:
👉 CLICK HERE 👈
[/quote]
[-] The following 4 users Like atram's post:4 users Like atram's post
  â€¢ ssobhan, malc, tluc, Dell_Brett
 ssobhan
User ID: 1054
Threads: 224
Given Likes: 2465
#119
02-11-2013, 09:13 PM
Dear friend;
Please if you can, share these images and document;
Images:
👉 CLICK HERE 👈
document;
Description of stress-strain curves by three parameters
Ramberg, Walter; Osgood, William R.
👉 CLICK HERE 👈
thanks in advance
  â€¢
 atram
User ID: 34120
Threads: 29
Given Likes: 436
#120
02-12-2013, 02:32 PM
here you are:
👉 CLICK HERE 👈
  â€¢ Dell_Brett, ssobhan, malc
Pages (23): « Previous 1 … 7 8 9 10 11 12 13 14 15 16 17 … 23 Next »
  [REQUEST] Some useful seismic reports miquan 4 3,864 07-14-2015, 01:58 PM
Last Post: atram
